Using the famous test hook. I had some difficulty finding a workflow, but here are my notes in case you also want to experiment with this. I ended up going via Paraview, credit to this thread which had most of the details I needed.
- Create body, or import mesh and convert to solid in Part workbench
- Switch to FEM workbench
- Create FEM analysis container
- Create material for part, e.g. PET
- Add fixed constraint on some faces
- Add force constraint on some other faces
- Add mesh. Can be problematic, I found gmesh ok, but best to start with coarse mesh and see how it goes.
- Open "SolverCcxTools"
- Select "Static" and "Write .inp file"
- Run Calculix
- Import .vtk file into Paraview
- Here we can visualize stress etc. as in Freecad. I based the reinforcement mesh on the von Mises stress, following Stefan.
- Select "clip" filter, select clip type = scalar, choose a value and select invert. Select "apply"
- Add "extract surface" extractor to remove internal geometry etc.
- "Save data" allows export as stl
- Import original mesh
- Right-click, add modifier, load...
- Choose saved output from Paraview. It should line up exactly with the existing mesh
- Right-click on the modifier mesh and select the desired reinforcement infill level.
