From FreeCAD To The Real World
haegar
Re: From FreeCAD To The Real World
Post by haegar »
Dear Keith and Thomas,
here is the test file:
I have taken the FREEship default hull, saved it as IGES (new model). Loaded into FC gave a blank screen.
Loaded into TCAD2018 and saved as IGES again (TCAD Test)
FC could read it as a compound of 4 surfaces. By exploding the compound and upgrading the 4 surfaces into a shell (DRAFT WB), I got at least the screeenshot picture. But here ends the story. I failed in making a solid out of it, because I could add the missing faces but I could not make a shell of it.
Of course, I can make a full hull in FREEship, but reformatting the file with a third party software and clicking then on every single surface segment is a bit impractical. The real hull is a bit more complex ...
One remark to FREEship and the "real world example": Although I use DELFTship sometimes for designing a hull, I have NOT the pro version. For getting an IGES file I have to downgrade the hull to FREEship 2.6, but this is usually no problem
OS: Windows 10 Version 2009
Version: 0.21.30058 (Git)
Hash: cb96332a64db8ae855ca700212eebb0f5151230a
Installed mods:
  * 3D_Printing_Tools
  * A2plus 0.4.54b
  * AirPlaneDesign 0.4.0
  * Assembly4 0.11.8
  * BOLTSFC
  * CurvedShapes 1.0.0
  * Curves 0.3.0
  * fasteners
  * Help 1.0.3
  * Manipulator
  * MeshRemodel 1.8918.0
  * nurbs
  * Plot
  * Render 2022.1.0
  * Ship
  * Silk 608221424.0.0
TCAD export loaded into FC
Screenshot 2022-08-22 120050.jpg (34.63 KiB) Viewed 7453 times
TCAD Test.IGS
loaded into TCAD and saved
(42.92 KiB) Downloaded 111 times
New model.igs
Freeship Testfile
(14.89 KiB) Downloaded 104 times
Regards from Teltow, Germany
Achim
keithsloan52
Post by keithsloan52 »
haegar wrote: Mon Aug 22, 2022 10:22 am Dear Keith and Thomas,
I note that Gmsh like FreeCAD uses OpenCascade to import IGES files, like FreeCAD, Gmsh just displays a blank screen.
I see FreeShip does not run on a Mac which is what I have, wondering if there are options in FreeShip related to IGES export.
haegar
Post by haegar »
no options, just simply export as IGS ...
Achim
hammax
Post by hammax »
... parts of the above "IGES-ship thread" should be moved to Help => no more show.
(I'm also getting files delivering a blank screen)
Generating an IGES file out of FreeCAD_0.20.1 under Win 10
looking for file header and format differences ???
Unnamed-Loft.iges
FC.20.1
(52.37 KiB) Downloaded 114 times
thschrader
Post by thschrader »
Antenna-mast in Switzerland. Bolted at a concrete wall.
Steel construction with FC, Techdraw, and of course, some FEM-stuff.
ThanklessLiving
Post by ThanklessLiving »
thschrader wrote: Fri Aug 26, 2022 3:33 pm Antenna-mast in Switzerland. Bolted at a concrete wall.
Magnificent!
I see some optimizations could be made by replacing the flat rectangle + triangle part with a section of another I-beam but I suppose for just one part it doesn't matter that much. Looking at the oval holes required in your model, if they are subcontracting this with one of those mighty Deutsch tube&profile lasers then cutting it from the same stock as the horizontal I-beam would be more efficient as there is less welding involved.
thschrader
ThanklessLiving wrote: Fri Aug 26, 2022 7:24 pm I see some optimizations could be made ...
Thanks for having a look at the model.
Some hints:
I had only 3 old building plans (scanned, pdf), which I scaled and stitched together in FC.
Can I rely on this alone? For instance, the roof overhang (?) was not clear, so I needed
another pair of longholes. The longholes and the clamps (2) are needed vor vertikal adjustment
of the mast. Part (1) can be done as you suggested, but I could use this part from another project :)
Greetings Thomas
Kuzma30
Post by Kuzma30 »
From here https://forum.freecadweb.org/viewtopic.php?f=3&t=71552 to real life.
Will add more images later.
RealThunder's A3 Wiki translation, join the project https://crowdin.com/project/freecad-asm3-wiki
thomas-neemann
Post by thomas-neemann »
here is a result of a participant of the vhs web seminar
cos4
Post by cos4 »
3D Printer loosely based on the Hypecube Evolution but in the end almost completely designed in FreeCAD. Actually this was my first real FreeCAD project. I really like the performance of Asembly4 and the ability to link objects (incl. Spreadsheets) between files the design very parametric.
Files can be found on Thingiverse: https://www.thingiverse.com/thing:5721422
