MOTOR ESTRELLA
pmlee
MOTOR ESTRELLA
Post by pmlee »
This is my recent work: MOTOR ESTRELLA.
I spend a lot of time creating this model. Especially the propeller part. It is very challenging.
The plan of this model can be found here:http://planosconciri.blogspot.com/2010/ ... rella.html
Re: MOTOR ESTRELLA
Can you give some information how you modeled it, workbenches used, suggestions for success?
pmlee
Re: MOTOR ESTRELLA
Post by pmlee »
The most difficult part is the propeller part. Especially the curve surface like the following:
You need to think of the corresponding position between the propeller and the nose like the following:
Except that, this model is not that hard to model and assemble.
pmlee
Re: MOTOR ESTRELLA
Post by pmlee »
phpBB [video]
I've create animation of this engine using Assembly 4 workbench. This is very fun! I enjoy the process very much!!
ppemawm
Re: MOTOR ESTRELLA
Post by ppemawm »
pmlee wrote: Fri Jan 13, 2023 5:49 pm
Most excellent! Thank you for sharing.
Could you please add a brief description of how you set-up the assembly LCS's and constraints for the animation? It would be helpful to all of us engine modelers.
pmlee
Re: MOTOR ESTRELLA
Post by pmlee »
ppemawm wrote: Fri Jan 13, 2023 6:05 pm
This is a very good question. I've create a short video to demonstrate the "bones" I created in the animation for you as a reference. I hope this short video helps.
phpBB [video]
ppemawm
Re: MOTOR ESTRELLA
Post by ppemawm »
pmlee wrote: Sun Jan 15, 2023 1:38 pm I've create a short video to demonstrate the "bones" I created in the animation for you as a reference.
Thank you, very interesting.
It appears that you are using a master sketch(es) of the master and slave connecting rods as a solver for Assembly4. Could you include a screenshot of the sketch showing the LCS attachments? I am assuming you attached the connecting rods to the sketch.
It would also be helpful to new users if you could include an image of the tree in the Assembly4 file. Also, please comment on how you structured your part files, any sub-assemblies, attachment offset variables, etc. for their benefit from all your good work.
Zolko
Re: MOTOR ESTRELLA
Post by Zolko »
Nice !!! Did you concatenate several videos into one (but then, how did you manage to make it turn continuously ?)), or did you make an intermediate variable that progressively shows parts that were hidden (but then, how on earth did you get this working ?) ?
Are you going to simulate the valves too ?
pmlee
Re: MOTOR ESTRELLA
Post by pmlee »
ppemawm wrote: Sun Jan 15, 2023 4:34 pm
Sorry to respond late. We just have our new Rabbit Lunar Year vacation. In order for all of you to learn how I create this model. I've upload the origional .FCStd files to GrabCAD. The url is:
https://grabcad.com/library/motor-estrella-19
Now! All the secrets are revealed~~ Happy Modeling!!
pmlee
Re: MOTOR ESTRELLA
Post by pmlee »
Zolko wrote: Mon Jan 16, 2023 8:38 am
This video is actually combined from 3 different videos (with different angles). The variable I use is only one: angle. I've upload the origional .FCStd files to GrabCAD. You may download all the files if you like:
