Arch SectionPlane Behaviour
PheasantCoucal
Post by PheasantCoucal »
Could someone please clarify what I should expect from Arch Section Plane. In the attached SectionTest001.FCStd there are two Arch Structures, one intersected by the Section plane, the other is behind it. Whether or not either of those structures are included in the Section Objects seems to have no effect on the resultant view. I was expecting that Objects named in the Object list would not be displayed when Cut View=True.
Thanks,
Rik
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * BIM 2021.12.0
  * dodo
  * Manipulator
  * MOOC
  * parts_library
  * Render 2022.1.0
(14.18 KiB) Downloaded 24 times
Roy_043
Re: Arch SectionPlane Behaviour
Post by Roy_043 »
If "Cut View" is set to true, the cut is shown in the 3D view. Objects that are not in the Objects list will not appear in the view (TechDraw_ArchView or Draft_Shape2DView) created from the SectionPlane.
PheasantCoucal
Thanks Roy. I eventually came to grips with the behaviour of the Arch Section Plane tool. It wasn't quite what I had expected but I now have it sorted. Thank you for your clarification.
