Posts: 13434 Joined: Thu Jan 05, 2017 9:03 pm
Post
by Kunda1 » Fri Oct 21, 2022 12:32 pm
paullee wrote: ↑ Fri Oct 21, 2022 3:59 am
Trying to install - it is BOLTSFC in FC Add-on right?
Install the
workbench , not the macro
paullee
Posts: 5136 Joined: Wed May 04, 2016 3:58 pm
Post
by paullee » Fri Oct 21, 2022 1:06 pm
Kunda1 wrote: ↑ Fri Oct 21, 2022 12:32 pm
Install the
Thanks, there is only 1 BOLTSFC, is it the WB? Installed
Screenshot from 2022-10-21 20-58-28.png (69.28 KiB) Viewed 1253 times
Screenshot from 2022-10-21 21-02-04.png (94.85 KiB) Viewed 1253 times
Screenshot from 2022-10-21 21-04-30.png (137.6 KiB) Viewed 1253 times
OS: Fedora Linux 36 (Workstation Edition) (GNOME/gnome)
Version: 0.21.30345 (Git)
Hash: f42a47aa0fd8c4f34ef63c185d9f29b9b6e84737
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
* dodo 1.0.0
* DynamicData 2.46.0
* ArchTextures
* Another link to SketchArchLite
* BOLTSFC.backup1666323893.5041647
* BOLTSFC
* FreeCAD-BlenderBIM.backup1666328110.015535
bernd
Posts: 12851 Joined: Sun Sep 08, 2013 8:07 pm
Post
by bernd » Sat Oct 22, 2022 7:49 pm
BOLTS is not a Workbench, but it is installed like a workbench because it needs a directory. Thus to start BOLTS you need to run the macro start BOLTS.
It is on a TODO to make a real Workbench out of BOLTS, but this never happend.
paullee
Post
by paullee » Sun Oct 23, 2022 1:51 am
bernd wrote: ↑ Sat Oct 22, 2022 7:49 pm
Thanks for clarification
Hiccup on running the macro reported in
https://forum.freecadweb.org/viewtopic. ... 44#p634840 , any idea ?
Screenshot from 2022-10-21 11-50-29.png (156.14 KiB) Viewed 1180 times
bernd
Post
by bernd » Mon Oct 24, 2022 6:24 am
would you post your FreeCAD info?
Would you try in FreeCAD python console and post the output:
Would you have a look at your user Mod directory? Is there a directory named BOLTSFC. Has it some contents?
bernd
Post
by bernd » Mon Oct 24, 2022 6:50 am
wow I did not know about this. It even works with python.
Anyway, BOLTS could work with any CAD which does have a Python API. ATM only FreeCAD and OpenSCAD are supported very well. I did implement in a PoC a AddOn for Nemetschek Allplan which worked out too. It means once put in all the data and use it in multiple CAD environments. Ahh it is even presented on the internet too.
https://www.bolts-library.org/
Damn the page if offline somehow ...
Lot's of work to do for BOLTS ...
bernd
Post
by bernd » Mon Oct 24, 2022 8:04 am
Moult
Posts: 321 Joined: Sat Jan 05, 2019 11:46 am
Post
by Moult » Mon Oct 24, 2022 12:56 pm
Welcome back from holiday bernd! Indeed I would be interested in bolts more than the spreadsheet feature since I plan to implement this in IFC.
Would it be possible to schedule a call?
I also blog about 3D rendering, architecture, software and other on
thinkMoult.com . RSS / Atom feed available for your convenience.
