Quotation marks in Shape from text
mfraz74
Re: Quotation marks in Shape from text
Post by mfraz74 »
mfraz74 wrote: Tue Oct 04, 2022 4:50 pm Just tried to use a quotation mark in the Draft WB's Shape from text tool and get the error:
1.12302 <asm3.main> init_gui.py(14): no solver backend found
  File "/tmp/.mount_FreeCAdOZlpR/usr/Mod/Draft/drafttaskpanels/task_shapestring.py", line 216, in accept
    Gui.doCommand(o+".String=\"" + string + "\"")
<class 'SyntaxError'>: ('unterminated string literal (detected at line 1)', ('<string>', 1, 65, 'FreeCAD.ActiveDocument.getObject("ShapeString").String="1 x 1/2""', 1, 65))
^CTraceback (most recent call last):
  File "/tmp/.mount_FreeCAdOZlpR/usr/Mod/Tux/NavigationIndicatorGui.py", line 50, in changeEvent
    def changeEvent(self, event):
KeyboardInterrupt
OS: Ubuntu 22.04.1 LTS (KDE/plasma)
Version: 0.21.30492 (Git) AppImage
Hash: b4578fb3eae842eb510a1bc055d07d369a67ce94
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
  * sheetmetal 0.2.57
  * Manipulator 1.4.9
  * lattice2 1.0.0
  * fcgear 1.0.0
  * Curves 0.5.8
  * Assembly4 0.11.8
  * fasteners
  * A2plus 0.4.59d
  * ThreadProfile 1.84.0
  * Assembly3 0.11.3
  * VendorParts
Looks like you need to escape the " with a '\'
Roy_043
Post by Roy_043 »
https://github.com/FreeCAD/FreeCAD/pull/7558
Workaround for the current (and older) versions: Add the double quotes later by editing the String property in the Property editor.
onekk
Post by onekk »
Only a suggestion to avoid substitution with "escape sequences"
string = """ " """
print(string)
It usually suffice, without escaping, but you have to see how the string is used.
triple quotes are used around when as example dealing with formatted text with "single quotes" and "double quote" in it.
you could use ''' or """ as terminator, Python is clever enough to detect the Start and end pattern, the problem is that """"""" (in other word a single "double quote" enclosed in "a triple double quote" separator sequence is giving error)
But this is a corner case.
Hope it helps.
Carlo D.
- Various other stuffs.
Roy_043
Post by Roy_043 »
There is probably another corner case: a triple double quote might occur in the string. AFIACT escaping the double quotes does not have similar corner cases.
