Creating an angular dimension when running under KDE
hko
Post by hko »
Documentation suggests I should hold down Alt key and select two edges, which I'd do with left mouse button, but Alt+LMB is grabbed by the window manager. It is the default combination for moving windows. I can change it as a workaround, but I'd prefer that FreeCAD could be used with the default window manager shortcuts if it purports to support Kubuntu.
It looks like "Alt key" is whatever is configured as "Alt Mod" in preferences but only options other than Alt are Shift and Ctrl so you can't utilize all available modifiers and Shift and Ctrl already have "standard" useful purposes.
Assuming I'm not missing any alternative method, maybe it would be useful if there was a separate command for an angular dimension? Or some radiobutton type selection in the dimension task dialog?
OS: Ubuntu 20.04.4 LTS (KDE/plasma)
Version: 0.20.24436 (Git)
Build type: Debug
Hash: ecbd151b114e086ee72d6142ace5780f6220c08a
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.3.0
Installed mods:
  * 3DfindIT 1.2.0
  * Render 2022.2.0
  * BIM 2021.12.0
  * Manipulator 1.4.9
  * parts_library
  * dodo
Roy_043
Re: Creating an angular dimension when running under KDE
Post by Roy_043 »
You can use the E key:
E, then LMB, then E, then LMB.
Holding down E also works:
Hold down E, then 2x LMB.
hko
Post by hko »
Roy_043 wrote: Tue Aug 02, 2022 10:58 am You can use the E key:
Thanks, I didn't realize to try E again while the dimension line positioning is in progress, after the first E + LMB. Wiki doesn't mention this either.
