Page 2 of 2
Re: (WORKAROUND) Zoom to fit freeze 3d window?
Posted: Mon May 23, 2022 5:18 pm
by Roy_043
When you use
Std_ViewFitAll on an empty model the problem does not occur. A similar solution could be implemented for
Std_ViewFitSelection when a point is selected.
Posted: Mon May 23, 2022 5:25 pm
by thomas-neemann
unfortunately that doesn't work for me either. it is not a problem for me. I am currently developing a freecad training course. I run into this problem when doing an exercise. i will use 0.19.3 for this exercise and it will work around the problem
Posted: Mon May 23, 2022 5:27 pm
by Roy_043
My previous post was a suggestion for Yorik.
Posted: Tue May 24, 2022 9:24 am
by yorik
Hmm yes... setting a minimum distance maybe, that might be a good idea indeed
Posted: Wed Nov 23, 2022 5:14 pm
by thomas-neemann
the error is still there for me
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.21.31058 (Git) AppImage
Hash: e6c53d8642af36ce7d738ab6058b063ec58e0859
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Posted: Thu Nov 24, 2022 7:59 am
by jeno
thomas-neemann wrote: ↑Wed Nov 23, 2022 5:14 pm
I was able to reproduce the problem and saved the file at that state.
Unpacked the file and checked the camera settings at the very end of GuiDocument.xml
<Camera settings="OrthographicCamera { viewportMapping ADJUST_CAMERA position -nan -nan -nan orientation 0 0 1 0 nearDistance 0 farDistance 0 aspectRatio 1 focalDistance 0 height 0 } "/>
Two strange things
- position is normally three floating point values (x,y,z) but -nan doesn't make any sense to me. Could also not find anything in the Coin-docs
- nearDistance clipping plane as well as farDistance clipping plane are set to 0. That means there is in fact no visible range for the camera
Please check that in your file and confirm.
cheers
Posted: Thu Nov 24, 2022 8:02 am
by thomas-neemann
jeno wrote: ↑Thu Nov 24, 2022 7:59 am
thanks for the cooperation. Unfortunately I can't find any file
Posted: Thu Nov 24, 2022 8:08 am
by jeno
thomas-neemann wrote: ↑Thu Nov 24, 2022 8:02 am
see wikipage
File Format FCStd
cheers
