Page 1 of 1
(SOLVED) I can't change the grid spacing in the weekly version
Posted: Sat May 14, 2022 6:22 am
by thomas-neemann
If I start the weekly version with deleted configuration files, I cannot change the grid spacing.
if I start and end once 0.19.3 it works. apparently 19.3 creates a file that is required by the weekly version and is missing.
- Bildschirmfoto_2022-05-14_08-09-23.png (104.17 KiB) Viewed 1306 times
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.28857 (Git) AppImage
Branch: (HEAD detached at fe4f6e0)
Hash: fe4f6e0aec3f00a5a9595bd50ba90dd866326321
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
edit
changing the setting has no effect
Re: I can't change the grid spacing in the weekly version
Posted: Sat May 14, 2022 6:52 am
by thomas-neemann
workaround
if you e.g. 0.20.26720 starts you can change the settings effectively, the weekly version adopts the values, but cannot change them effectively yourself.
Re: (WORKAROUND) I can't change the grid spacing in the weekly version
Posted: Sat May 14, 2022 8:18 am
by Roy_043
Posted: Sat May 14, 2022 8:20 am
by thomas-neemann
Thank you. is the problem being worked on?
Posted: Sat May 14, 2022 8:27 am
by Roy_043
IMO the commit should be reverted. I have added a comment to that effect:
https://github.com/FreeCAD/FreeCAD/pull ... 1126669377
Posted: Sat May 14, 2022 8:29 am
by thomas-neemann
Posted: Fri May 20, 2022 7:19 pm
by thomas-neemann
the problem is still there
Version: 0.20.28909 (Git) AppImage
Branch: (HEAD detached at 2084652)
Hash: 20846523c9d8219ec0fe33c499a64e700d2266b6
Posted: Mon May 23, 2022 4:07 pm
by openBrain
Good news that it didn't solve by itself.
A first PR is here :
https://github.com/FreeCAD/FreeCAD/pull/6899
Seems to be some more issues to solve in Draft itself where you can change grid size outside the preferences. Will look a bit later (hopefully).
Posted: Mon May 23, 2022 4:13 pm
by thomas-neemann
thanks for the cooperation
Posted: Thu Jun 02, 2022 7:43 pm
by thomas-neemann
now it works, thanks
Version: 0.20.28993 (Git) AppImage
Branch: (HEAD detached at 6d92e53)
Hash: 6d92e532bcc31c99a0ab4c153ff00b6414b8f527
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
