Custom Working Plane Not Set on Arch Slab Face
I am unable to set a custom working plane on an Arch Slab face. Could anyone please tell me what I could be doing wrong here? I have attached a GIF for reference. I can set the working plane to Arch Wall faces but not the slab face.
- FreeCADCustomPlane2.gif (973.64 KiB) Viewed 883 times
- ragohix769
Re: Custom Working Plane Not Set on Arch Slab Face
The selection of a face sometimes it's not working (especially in "auto" mode), I confirm. But if you insert a file project here, I can test it to confirm, because I tried with a simple slab created by me and it's working (superior face).
- wepz.png (322.52 KiB) Viewed 822 times
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same
Thank you; will post the project file soon. I will share a file soon to illustrate the problem.
For the time being I went ahead and created a proxy plane to circumvent that problem.
I have attached the file that I am currently working on. I am basically trying to explore how everything works and understand how best to use it for actual real world projects. Any help in that regard is appreciated. I also noticed that the Level-Axes bubbles do not show up in Tech Draw and also the Labels for the same show up somewhere else. Anyway, I will create separate posts for these two issues.ragohix769 wrote: ↑Mon Apr 11, 2022 9:44 amThe selection of a face sometimes it's not working (especially in "auto" mode), I confirm. But if you insert a file project here, I can test it to confirm, because I tried with a simple slab created by me and it's working (superior face).
- Trial House.FCStd
- (198.47 KiB) Downloaded 25 times
