v0.20dev "Unmanaged change of Constraint Property results in invalid constraint indices"
Post by Kunda1 »
When opening the Start WB example file ArchDetail.FCStd, it spits out this warning:
SketchObject::onChanged(): Unmanaged change of Constraint Property results in invalid constraint indices
OS: Ubuntu Core 20 (KDE/plasma)
Version: 0.20.28163 (Git)
Hash: 88daed86eab75dc85a46c11e670b4a55cc2cb36a
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, OCC 7.6.1
Locale: C/Default (C)
Installed mods:
  * ToolbarStyle
  * Assembly4 0.11.10
  * stickframe
  * sheetmetal 0.2.49
  * Behave-Dark-Colors 0.0.1
  * Curves 0.3.0
  * Ship
  * BIM 2021.12.0
Re: v0.20dev "Unmanaged change of Constraint Property results in invalid constraint indices"
Post by Kunda1 »
Is it due to what abdullah writes here: https://forum.freecadweb.org/viewtopic. ... 55#p457455 ?
Roy_043
Post by Roy_043 »
The error message is not very informative. But the file has other issues. It is almost 6 years old and as such does not represent the current state of the Arch WB, it uses the obsolete Drawing WB for its drawing, and a full recompute fails because of another error. My suggestion would be to remove it from the examples folder.
Roy_043 wrote: Thu Apr 14, 2022 9:13 am My suggestion would be to remove it from the examples folder.
In this state yes. But perhaps there is a volunteer ...?
