Page 2 of 5
Re: Arch/Bim Wall Bug?
Posted: Mon Mar 14, 2022 11:20 am
by Roy_043
Outsourced wrote: ↑Mon Mar 14, 2022 5:05 am
See Bedroom 1 Wall Connections
This is more than a display error. It is a strange problem. F.e. deleting the line for the back wall of bedroom 2 fixes the problem somehow. Not that that is a solution of course.
Posted: Mon Mar 14, 2022 4:39 pm
by paullee
Outsourced wrote: ↑Mon Mar 14, 2022 8:07 am
T.N
Thx for the file and effort, It appears I will cont. with my intro into Arch/Bim using this method, or as you suggest ignore.
However, I do request this to be raised as a bug, WIZIWIG If your a relative new user flags will be raised if you are getting gaps in your walls. When your opening a cad package and your having trouble with this basic process, and you really shouldn't have to do things twice to get a flawless result, to me that is the definition of Bug!
This is a known problem I want to fix for a long while
I use Sketch as base of Wall a lot, but seldom drop into this problem, you may have a look at
Villa Savoye or
github. An ugly and tedious 'workaround' is to make a construction edge with the (half) width of wall to set back the edge ... maybe someone want to attack this ?
- Screenshot from 2022-03-15 00-17-04.png (206.13 KiB) Viewed 1824 times
- Screenshot from 2022-03-15 00-19-06.png (217.98 KiB) Viewed 1824 times
- Screenshot from 2022-03-15 00-19-12.png (224.04 KiB) Viewed 1824 times
- Screenshot from 2022-03-15 00-19-19.png (214.13 KiB) Viewed 1824 times
- Screenshot from 2022-03-15 00-20-36.png (215.61 KiB) Viewed 1824 times
- Screenshot from 2022-03-15 00-20-43.png (209.9 KiB) Viewed 1824 times
- Screenshot from 2022-03-15 00-20-53.png (225.48 KiB) Viewed 1824 times
Posted: Tue Mar 15, 2022 5:11 am
by Outsourced
I redrew via sketcher / pad &
- Hole_Depth.png (866.51 KiB) Viewed 1779 times
to find Hole 0.00mm caused problem regardless I found a happy hole depth at 400mm. Not sure why the generic 0.00mm pockets the adjacent wall? Also sounds like a bug!
Thx for the help, V's No.12 should return useable CAD?
Posted: Tue Mar 15, 2022 5:37 am
by paullee
0 means automatic, but somehow it generate a subtraction volume, when use complex sketch as base, which cut adjacent wall segment.
People who do not use complex sketch has no such problem.
Prepared to improve the algorithm, see
Cutting hole depth
Posted: Wed Mar 16, 2022 11:04 pm
by Outsourced
FC:-19.3, FC:-0.20, FC:-LS3
1. Use Draft -Problem: Draft is not Parametric
2. Use Simple Sketch- Wall connection Rendering Problem
3.use 3 sketches as layers 1st sketch parametric grid, 2nd Sketch drive grid & wall constraints location & Thickness, 3rd prepare wall for Pad. (Problem Attached)
https://drive.google.com/file/d/1_X8xgv ... sp=sharing
Sketch goes into meltdown.
file included.
So at this point in time, to have a flawless parametric rendering isn't achievable - I hope these files & comm's help the dev's. Thx for the software.
Regards
Hyme
Posted: Thu Mar 17, 2022 3:08 am
by paullee
Draft Line / Polyline is parametric, you can use Edit Polyline to do editing. But it does not have constraints which to me are very useful for organisation and revision indeed so I stick with Sketch
You has to link the same, no file attached.
Posted: Thu Mar 17, 2022 3:29 am
by paullee
paullee wrote: ↑Mon Mar 14, 2022 4:39 pm
Villa Savoye or
For anybody want to attack this, I can describe the algorithm behind and the line of code relevant - in gist, the created wire for the base face of the wall is self-intersecting and after Part.fix(shape), the portion 'self-intersecting' become blank instead of face...
Posted: Thu Mar 17, 2022 6:00 am
by Outsourced
Ok Glad you all know about it, I went to sketch parametric grid FC 0.19.3, then sketch on top to lay the walls down still got an error of 1 void in the Bedroom 2 wall.
https://drive.google.com/file/d/1YjbWVs ... sp=sharing
I am now convinced FC 0.20 LS3.118 are unstable.
ON WINDOWS 10
PS. Thx for all the work you guys do - I wish I contribute more
Regards
Hyme
Posted: Thu Mar 17, 2022 6:10 am
by thomas-neemann
Outsourced wrote: ↑Thu Mar 17, 2022 6:00 am
if you know freecad well and use it accordingly, it is very stable, especially under linux (xubuntu lts)
Posted: Thu Mar 17, 2022 3:11 pm
by paullee
