Lock angle line in Draft
matthyuz
Post by matthyuz »
OS: Windows 10 (10.0)
Version: 0.20.27809 (Git)
Python 3.8.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: Spanish/Argentina (es_AR)
Installed mods:
* fasteners
* fcgear
* sheetmetal
Hello, everyone.
I am confused with how the line tool works in Draft.
What I am trying to replicate is the angle lock, just like what is performed at minute 3:14 of the attached video. In that video the key to lock the angle is L (lock), but in later versions of FreeCAD, it is the H key.
The problem I see is that after pressing the H key (having enabled the line end snap), when moving the mouse pointer, the line is locked at an angle, but does not pass through the expected point. It appears displaced a few degrees.
I also tested with the Polyline tool; it seems to work correctly, although in some tests the same error appeared (this last one testing in 3 dimensions).
Can someone test and tell me if the operation of this H key is as expected?
Thank you very much.
https://www.youtube.com/watch?v=KpEl2Jt ... zalezGomez
thomas-neemann
Re: Lock angle line in Draft
Post by thomas-neemann »
that doesn't work for me either. the function is currently being worked on. here is a workaround
https://www.youtube.com/watch?v=pp0lb_89n-s
phpBB [video]
matthyuz
Post by matthyuz »
Hi Thomas and thanks for confirming that it is not working properly.
I am glad that work is being done to fix this feature, I find it very useful.
I am interested in getting some notice when it is resolved so I can help by testing.
Regards.
thomas-neemann
matthyuz wrote: Sat Mar 12, 2022 3:00 pm ...
Regards.
here is a fix that might work. gladly feedback
https://forum.freecadweb.org/viewtopic. ... 63#p578291
matthyuz
Post by matthyuz »
Hi Thomas, thanks for the heads up, but I don't know how I should test this solution.
Should I wait until it is merged?
thomas-neemann
matthyuz wrote: Sun Mar 13, 2022 10:31 pm Hi Thomas, thanks for the heads up, but I don't know how I should test this solution.
Experience has shown that something like this will be available here in 1 to 2 weeks
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
matthyuz
Post by matthyuz »
Hi Thomas, do you know when this will be fixed or if it is planned to be fixed?.
I downloaded the latest development version (28717) and the problem persists.
Roy_043
Post by Roy_043 »
While testing this I have found an issue with the PR mentioned in the topic Thomas linked to. But this does not affect the workflow shown in the video tutorial. I suspect that your problem is related to having Draft_Snap_Near active. Please switch that off and check again.
matthyuz wrote: Sat Mar 12, 2022 12:54 am I also tested with the Polyline tool
I do not understand this. The lock angle option is not available for polylines (see Draft_Wire).
thomas-neemann
matthyuz wrote: Wed Apr 20, 2022 11:30 am Hi Thomas, do you know when this will be fixed or if it is planned to be fixed?.
I do not know
Roy_043 wrote: Wed Apr 20, 2022 6:18 pm ....I do not understand this....
apparently it works now, but the value jumps and it is inaccurate. in 0.18 it was still fine
t1.FCStd
(6.12 KiB) Downloaded 21 times
https://www.youtube.com/watch?v=64-hsEpIKkM
phpBB [video]
Roy_043
Post by Roy_043 »
Confirmed. Here is a modified DraftGui.py file that I think fixes this problem, as well as the problem I discovered yesterday.
Note that there is a fundamental issue with this, and other, Draft task panels. The input boxes are also used to display the coordinates of the point in the 3D view. This display is controlled by the "Number of decimals" preference. There is an ambiguity. When the user presses the "Enter point" button what is being confirmed? The actual coordinates of the 3D point, or the rounded representation in the task panel? In many cases the Draft code reads the rounded coordinates from the task panel and uses those. This can lead to unexpected inaccuracies and may in fact explain the problem @matthyuz is experiencing.
So the general advice is that for the Draft WB the "Number of decimals" preference should not be set too low.
DraftGui.py
(103.19 KiB) Downloaded 27 times
