Yes, of course!Roy_043 wrote: ↑Mon Feb 28, 2022 4:20 pm [*]Apply a Sketcher ConstrainDistance constraint to one of the sides. The dimension should be PolygonOutlineLength/n
Draw a polygon by a given circumference
Re: Draw a polygon by a given circumference
Thanks a lot. This would be the usable solution.Roy_043 wrote: ↑Mon Feb 28, 2022 4:20 pm The assumption is that the user knows the number of sides of the polygon:
- Create a sketch.
- Create a Sketcher CreateRegularPolygon with n sides. Place the center on the origin and the 'radius' point on the X axis.
- Apply a Sketcher ConstrainDistance constraint to one of the sides. The dimension should be PolygonOutlineLength/n
- The sketch should be fully constrained now.
