Arch Wall - Block Count (Count Entire & Count Broken)
Is Arch Wall - Block Count Accurate?
(Count Entire & Count Broken - https://wiki.freecadweb.org/Arch_Wall)
Is it still in development not yet completed?
I am trying to drill down into the details of FC for better understanding. I created a test two walls (refer to attached). Both simple and modular (block size 390×190mm and 10mm Joint). I counted the block (calculation attached).
Woops! No match between my calculated numbers and the Arch Wall - Block Count!
Why? Any comment please?
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- 3-Brick WallR3.FCStd
- (61.45 KiB) Downloaded 36 times
- New Bitmap Image.jpg (377.27 KiB) Viewed 2158 times
Re: Arch Wall - Block Count (Count Entire & Count Broken)
I have found the cause of the bug. The first block in each row has a length of BlockLength+Joint. And the code considers any block that does not have the standard measurements as 'Broken'. I am attaching the file with the fix and I'll do a PR.
- ArchWall.py
- (79.91 KiB) Downloaded 33 times
Many Thanks Roy_043
Hi Roy_043 and the FC’s Community
LinkDaily (Version attached below ) has implemented this thread’s PR (https://github.com/FreeCAD/FreeCAD/pull/4910)
Thanks.
The Latest FC “FreeCAD_weekly-builds-29126-2022-06-12-conda-Windows-x86_64-py38.7z” has not yet approved and merged it.
Any comment please?
OS: Windows 10 (10.0)
Version: 2022.430.26244 +4758 (Git)
Branch: LinkDaily
Hash: b024b876480a533018fdc702145e9e38f8c54ba6
Python version: 3.9.12
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
Version: 0.20.29126 (Git)
Hash: 6c1c63cffebe6a9d55bd9b1d8ca6b741a4d16548
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
* ArchTextures
* Behave-Dark-Colors 0.0.1
* BIM 2021.12.0
* Curves 0.4.4
* dodo
* fasteners 0.3.43
* FreeCAD_SketchArch-master
* Glass
* PieMenu
* pivy_trackers
* ProDarkThemePreferencePack 1.0.0
* Reinforcement
* Trails 2022.1.0
Thanks.
Any comment please?
Branch: LinkDaily
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
Installed mods:
* ArchTextures
* BIM 2021.12.0
* Curves 0.4.4
* dodo
* fasteners 0.3.43
* Glass
* PieMenu
* pivy_trackers
* Reinforcement
* Trails 2022.1.0
- 2.jpg (266.08 KiB) Viewed 1257 times
- 1.jpg (266.25 KiB) Viewed 1257 times
AFAICT the PR has been merged in master as well:
https://github.com/FreeCAD/FreeCAD/blob ... ll.py#L873
Some other piece of code has perhaps caused the regression. Will try to have a look later.
I can't reproduce. See attached file. Please post your file.
OS: Windows 8.1 (6.3)
Installed mods:
- wall-block-count.FCStd
- (11.49 KiB) Downloaded 18 times
Hi Roy_043
I have reattached the file (Also it is attached to the 1st part of this tread, refer to the top).
Thank for your quick response
Cheers
Cheers
- (61.45 KiB) Downloaded 16 times
Ah, the same file, I missed that.
Again I can't confirm.
Please verify that your ArchWall.py is correct. See attached.
If that does not help try renaming your user.cfg file.
- ArchWall.py
- (79.8 KiB) Downloaded 20 times
I tried the following with no luck:
1- Download your file "ArchWall.py" and past it over to replace my file at (... \FreeCAD_weekly-builds-29126-2022-06-12-conda-Windows-x86_64-py38\Mod\Arch)
2- delete all *.cfg files including all folder at C:\Users\User\AppData\Roaming\FreeCAD
And Install a fresh copy of FreeCAD_weekly-builds-29126-2022-06-12-conda-Windows-x86_64-py38
Can any one on the forum with the following setting (similar to my setting) confirm/check the brick count reported above.
