paullee wrote: ↑Mon Jan 31, 2022 10:07 am
With you oval stair, seems both either sides does not define the direction of the flight / treads - so my above concept of introducing a dedicated wire for 'path'/'axis'/'direction' of flight and another closed wire for the 'outline' of the flight is required for your case right ?
Yes, I think your concept could be an ideal solution.
When the dedicated wire for 'path/axis/direction' - I call it "walking path" - overlaps the outline wire, we would fall back to the actual situations.
All steps would have same treads-length along the walking path and intersect with it at right angles.
However, when generating the steps, we would have to make sure that they don't intersect within the closed wire for the 'outline'.
