Open Source House with Open Source CAD?
paullee
Re: Open Source House with Open Source CAD?
Post by paullee »
jsolersallent wrote: Mon Jun 06, 2022 10:50 am I'm trying to create the Sketch roof subtraction profile. With part design I can do it, but not with Arch sketch. When I create an archsketch and go to map mode it is locked and I can't put object xy. Could you tell me how to put the sketch upright?
Hi, not sure if you download the earlier model file to test or not.
Assume you have attached to an edge, try play with the AttachOffset Extra Rotation attribute.
Probably select X-Axis CCW90 would do the trick :)
Screenshot from 2022-06-06 23-13-29.png (279.88 KiB) Viewed 1596 times
jsolersallent
Post by jsolersallent »
Now works, thanks :)
hhassey
Post by hhassey »
Hello, I am planning to study, maybe even build this project. Unfortunately the link to the pdf project from Studiolada is broken. Can anybody share it here?
Thanks in advance..
thomas-neemann
Post by thomas-neemann »
hhassey wrote: Fri Jul 22, 2022 6:27 pm ...
Unfortunately the link is useless. but it also had static problems. here is another open source house
https://www.youtube.com/watch?v=RJ7RVCENP7o
hhassey
Post by hhassey »
thomas-neemann wrote: Fri Jul 22, 2022 6:50 pm Unfortunately the link is useless. but it also had static problems. here is another open source house
Thank you, what kind of "Static" problems?
thomas-neemann
hhassey wrote: Fri Jul 22, 2022 8:35 pm ..
The problem can be seen further up in this thread
hhassey
Post by hhassey »
Does anybody have the pdf file and could plese upload it? The original link is broken now.
paullee
Post by paullee »
hhassey wrote: Tue Jul 26, 2022 6:15 pm Does anybody have the pdf file and could plese upload it? The original link is broken now.
Screenshot from 2022-07-27 07-35-31.png (4.99 KiB) Viewed 1226 times
Found this, file too large to attach, any other convenient mean to transfer ? :roll:
hhassey
Post by hhassey »
Thank you so much @paullee please upload it here. :D :D
paullee
Post by paullee »
hhassey wrote: Tue Aug 02, 2022 2:16 am Thank you so much @paullee please upload it here. :D :D
Uploaded, good luck :)
