Open Source House with Open Source CAD?
thomas-neemann
Re: Open Source House with Open Source CAD?
Post by thomas-neemann »
With a point cloud from the site, you can quickly carry out a volume calculation in Freecad. something like that is used for cost accounting and is very time-consuming by hand.
thomas-neemann
I made a video about a volume calculation for my customers. If anyone else cares, here it is.
the scale is not adjusted. there was no information about the file.
ftp://ec2-52-45-144-142.compute-1.amazo ... ork_NE.xyz
phpBB [video]
paullee
Post by paullee »
thomas-neemann wrote: Sun Aug 02, 2020 11:59 am I made a video about a volume calculation for my customers. If anyone else cares, here it is.
phpBB [video]
Thanks for sharing.
Checkout the ArchSite wiki, which help to do similarly, though I have tried that.
thschrader
Post by thschrader »
thomas-neemann wrote: Sun Aug 02, 2020 11:59 am ...
The xyz-Geodata files from official government sites like this
https://www.geoportal-th.de/de-de/Downl ... B6hendaten
are simple text files with xyz-ccordinates of the points. Given in meters, resolution 25 m.
After meshing/importing in FC you must scale up the mesh by a factor of 1000 (when using default units mm in FC).
After upscaling the resolution is too rough for small construction sites. Where do your customers get the point-cloud from?
Lidar-scan?
www.vhive.ai
thomas-neemann
thschrader wrote: Mon Aug 03, 2020 6:55 am ping
my customers get the data from surveying companies.
I have found a nice page here (to the centimeter) I am currently in the process of creating a workflow.
https://www.opengeodata.nrw.de/produkte ... paketiert/
Bildschirmfoto vom 2020-08-03 09-02-20.png (251.61 KiB) Viewed 1602 times
Bildschirmfoto vom 2020-08-03 09-03-13.png (128.93 KiB) Viewed 1602 times
thomas-neemann
it works with real measurements. I'm trying to make a video of it
Bildschirmfoto vom 2020-08-03 10-47-51.png (115.66 KiB) Viewed 1580 times
thomas-neemann
if our house were to be built on this plot of land, 383 m3 of earth would have to be removed.
Bildschirmfoto vom 2020-08-03 12-41-14.png (53.54 KiB) Viewed 1560 times
Bildschirmfoto vom 2020-08-03 12-40-11.png (88.25 KiB) Viewed 1560 times
Bildschirmfoto vom 2020-08-03 12-48-22.png (74.99 KiB) Viewed 1560 times
thomas-neemann
here the workflow with real scale
https://www.opengeodata.nrw.de/produkte ... /dgm1_xyz/
phpBB [video]
thschrader
Adjustment:
Additional beams (1) 50x200 at upper floor. Now the statics work :)
Adjusted length of beams (2) due to new position of beam (4).
Beam (4) should have the red position (and a little bit higher of course) to have full
contact to the wall-panels. But then there is not enough space for the insulation. Mmmh…
The concrete panels (3) should be connected to the foundation for maximum shear-stability.
wood_structure_adjusted_03082020.ifc
(97.44 KiB) Downloaded 83 times
paullee
Post by paullee »
Cool !
