Can we change the default colours for edges and faces?
Moult
Post by Moult »
In FreeCAD, If I draw a rectangle, and then draw a line, they are almost the same colour, and are so hard to see. I consider this an accessibility issue? Admittedly upon rotation faces are lit, and therefore it can become easier to see, but still. Also, the preselection colour yellow doesn't have a large enough contrast to make it easy to see against the grey.
Here is an example in Blender where faces are grey, edges are black, and selected edges are orange. This is a better contrast and is easier to see.
For web accessibility, when distinguishing between different modes of UI, we have to consider the WCAG guidelines: https://webaim.org/resources/contrastchecker/ - I propose changing the FreeCAD default colours to be more accessible.
As an aside, is there a user setting somewhere to customise the workplane grid colour?
Thoughts?
Re: Can we change the default colours for edges and faces?
Have a look at Preferences->Display->PartColors
vocx
Post by vocx »
Moult wrote: Sat May 25, 2019 11:35 am ...
I don't know if carlopav or Yorik made recent changes, but it was exactly like you say. For a very long time the default edges were black and faces were gray. This changed fairly recently, I think.
Moult
Post by Moult »
chrisb wrote: Sat May 25, 2019 2:13 pm Have a look at Preferences->Display->PartColors
I'm referring to the defaults, yes, it should be user customisable.
Oddly enough my settings there are grey faces and black edges, so I wonder why my lines are also grey. Can somebody confirm this behaviour?
Which version do you use? Please attach your FreeCAD infos.
Moult
Post by Moult »
chrisb wrote: Sat May 25, 2019 10:34 pm Which version do you use? Please attach your FreeCAD infos.
OS: Gentoo/Linux
Version: 0.19.16830 (Git)
Build type: Unknown
Hash: a0497f42fd4f8a00e459660527e96b7aee9ca6bb
Python version: 3.6.5
Qt version: 5.11.3
To clarify, here are my settings which are unchanged from default:
Yet here is what an extruded rectangle and a draft line looks like:
Please switch to Draft workbench and check Preferences->Draft->Visual settings. There is another line color setting.
Moult
Post by Moult »
Thanks- that's the setting that changes it. So in conclusion:
1. Shouldn't we change the default so that edges and draft lines are the same?
2. I recommend changing lines to black so that it has a higher contrast
3. Can the default preselection colour also change to have a better contrast? See below WCAG check.
4. The preselection colour is affected by scene lighting. When it is set to yellow at certain angles it is very hard to see. In Blender, it is also affected by scene lighting but the colour is always very clear to see. See below example.
Thoughts?
I wonder how you got these default colors, perhaps a user.cfg is installed instead of created? I have never changed anything concerning line color and edges are always black - Draft or not.
Can you please
- quit FreeCAD
- move your ~/.FreeCAD/user.cfg to another name
- restart FreeCAD
- check if the colours have changed?
- restore user.cfg
If you haven't configured something you want to keep, you can simply use the Reset button in the preferences.
OS: macOS 10.13
Version: 0.19.16790 (Git)
Hash: 15f440525e59c3caf89f847a490981abf5a45f8f
Python version: 3.7.3
Qt version: 5.6.2
Moult
Post by Moult »
Thanks for helping debug chrisb. Deleting user.cfg indeed does restore the black lines.
I found that it is the BIM Workbench's start up wizard (the one which sets default values) which causes the white lines. Here are the exact steps:
1. Move ~/.FreeCAD/user.cfg elsewhere
2. Start FreeCAD. Switch to BIM workbench but when the startup wizard pops up, press "Cancel". Do NOT press "OK".
3. Start drawing, everything will be black lines. This is good.
4. Close FreeCAD.
5. Start FreeCAD again, switch to BIM workbench. Go to Manage->BIM Setup. On the startup wizard, this time, press "OK".
6. Close FreeCAD.
7. Start FreeCAD again. Now your lines will be white.
Can anybody else reproduce this? If so, I can look for a fix?
