I wish to write a Macro that process a directory, is there a good way to pass a file system path to a FCmacro?
Thanks
SOLVED : Passing a files system path to a FCMacro
Re: SOLVED : Passing a files system path to a FCMacro
from PySide import QtGui
name=QtGui.QFileDialog.getOpenFileName()[0]
In the end went with
import PySide
from PySide import QtGui ,QtCore
from PySide.QtGui import *
from PySide.QtCore import *
path = FreeCAD.ConfigGet("UserAppData")
#getExistingDirectory(QWidget *parent = nullptr, const QString &caption = QString(), const QString &dir = QString(), QFileDialog::Options options = ShowDirsOnly)
Directory = PySide.QtGui.QFileDialog.getExistingDirectory(None, "Select a directory",path)
print(f"Selected Directory {Directory}")
