Is there a workaround for Object Property names with a minus sign?
dan-miel
Post by dan-miel »
I’m adding Techdraw information into a FreeCAD Object. When I try to add some of the properties with minus signs in the name, such as FC-DATE and FC-Title, I get an error for an improper name is there a work around so I can keep the names matched. At the moment I’m thinking of a rewrite using dictionaries.
Dan
onekk
Re: Is there a workaround for Object Property names with a minus sign?
Post by onekk »
I don't think as sometime properties are used as "object properties" so you could retrieve their value in code as:
obj.property
You could easily see what problem will arise with a minus sign in the name.
Regards
Carlo D.
- Various other stuffs.
