[SOLVED] TechDraw: Align dimensions
RedTorch
Post by RedTorch »
I'm trying to get started with my first script...
Basically, how do I get all the selected objects? (BTW I'm in TechDraw)
Thanks
import FreeCAD
from FreeCAD import Base
import math, collections
from PySide import QtGui, QtCore
def get_selection():
	''' check selection of View and ObjectList '''
	OK, ObjectList, View = False, [], []
	if Gui.Selection.getCompleteSelection():
		View = Gui.Selection.getCompleteSelection()[0]
		ObjectList = Gui.Selection.getSelectionEx()[0].SubElementNames
		if len(ObjectList) > 0:
			OK = True
	return (OK,ObjectList,View)
	#return ObjectList
o = get_selection()
print(o)
RedTorch
Re: Newbie
Post by RedTorch »
It's rough but I think it works...
In TechDraw, select multiple Horizontal or Vertical dimensions, this will then set their position the same
*set where you want the label before using script!
import FreeCAD
print("\nDIMENSION ALIGN\n")
	View = []
	return View
o = get_selection()
#print(o)
#print(dir(o[2]))
#print(o[2].Type)
#print(o[2].X)
if len(o) > 0:
	if len(o) == 1:
		print("Select multiple objects (of same type)")
	else:
		#	GET FIRST TYPE
		o_type = o[0].Type
		#print(o_type)
		if o_type == "DistanceY":
			a = []
			#	ADD FIRST OBJECT
			a.append(o[0])
			#print(a)
			#	ADD OTHERS OF SAME TYPE
			for i in range(1, len(o)):
				#print(o[i].ID)
				if o[i].Type == o_type:
					a.append(o[i])
			#	DUMP
			#print(a)
			for e in a:
				#print("Label: ", e.Label)
				#print("Label2: ", e.Label2)
				print("Name: ", e.Name)
				#print("FullName: ", e.FullName)
				print("ID: ", e.ID)
			#	ALIGN X
			n = o[0].X
				o[i].X = n
		elif o_type == "DistanceX":
			a = []
			#	ADD FIRST OBJECT
			a.append(o[0])
			#print(a)
				#print(o[i].ID)
					a.append(o[i])
			#	DUMP
			#print(a)
			for e in a:
				print("ID: ", e.ID)
			#	ALIGN Y
			n = o[0].Y
				o[i].Y = n
		else:
			print("First selected object is not either DistanceY or DistanceX type")
Vadella
Re: [SOLVED] TechDraw: Align dimensions
Post by Vadella »
Here is a method where you don't have to do the
o=get_selection()
first.
The first parts gets the selection, checks whether it is not empty and filters it according to the type of the first element selected if needed.
The second part checks which attribute to set and sets it for all selected elements.
# -*- coding: utf-8 -*-
import FreeCAD
from FreeCAD import Gui
def align(check_type=True):
    selection = Gui.Selection.getCompleteSelection()
    if not selection:
        print("no objects selected")
        return
    first_type = selection[0].Type
    elements = [
        element for element in selection
        if (not check_type or element.Type == first_type)
    if len(elements) <= 1:
        print("select more than 1 element of the correct type")
        return
    if first_type == "DistanceX":
        attribute = "Y"
    else:
        attribute = "X"
    default = None
    for element in elements:
        if default is None:
            default = getattr(element, attribute)
            continue
        setattr(element, attribute, default)
align()
You can also copy the method definition in the python console, and then just call
align()
in the python console after selecting the elements
