[BUG] Part::FeaturePython with App::GroupExtensionPython
carlopav
Post by carlopav »
When adding an "App::GroupExtensionPython" to a "Part::FeaturePython" object, the result is an object that gets it's representation from its children. This seems weird, is it the default behavior?
class py_object:
    """Base class for all blenderbim objects"""
    def onChanged(self, obj, prop):
        return
    def attach(self, obj):
        obj.addExtension("App::GroupExtensionPython")
    def __getstate__(self):
        return None
    def __setstate__(self, state):
        return None
    def execute (self, obj):
        pass
class py_vp_object:
    """Base class for all blenderbim view providers"""
    def attach(self, vobj):
        self.Object = vobj.Object
        vobj.addExtension("Gui::ViewProviderGroupExtensionPython")
    def getDisplayModes(self, obj):
        return []
    def getDefaultDisplayMode(self):
        return "FlatLines"
    def setDisplayMode(self,mode):
        return mode
    def onChanged(self, vobj, prop):
        return
    def updateData(self, obj, prop):
        return
        return None
        return None
obj0 = FreeCAD.ActiveDocument.addObject('Part::FeaturePython', 'IfcObject', py_object(), py_vp_object(), True)
obj0.Shape = Part.Shape(Part.makeBox(1,1,1))
obj1 = FreeCAD.ActiveDocument.addObject('Part::FeaturePython', 'IfcObject', py_object(), py_vp_object(), True)
obj1.Shape = Part.Shape(Part.makeCylinder(0.5,3))
obj2 = FreeCAD.ActiveDocument.addObject('Part::FeaturePython', 'IfcObject', py_object(), py_vp_object(), True)
obj2.addObject(obj1)
obj1.addObject(obj0)
If you execute this code this structure is created:
The top level group, IfcObject002, does not have a shape, in fact:
App.ActiveDocument.IfcObject002.Shape.isNull() returns True
But it is represented on the scene and is selectable! :cry:
carlopav
Re: App::GroupExtensionPython on Part::FeaturePython
Post by carlopav »
If then for example you want to move one object, the one whose Shape isNull, you obtain this strange effect:
And you can select the object by clicking on its coin representation...
carlopav
Post by carlopav »
I feel this is a bug... I'm changing topic title.
The bug is present in 0.20 and also in last daily:
OS: Windows 10 Version 2009
Version: 0.21.30858 (Git)
Hash: 7a5019b2625a148acb23fb915df48ffa69636fe9
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: Italian/Italy (it_IT)
Installed mods:
  * 3D_Printing_Tools
  * A2plus 0.4.59e
  * ArchDesign
  * bimtester
  * BIM_Workbench 2021.12.0
  * BOLTSFC
  * Curves 0.5.11
  * Defeaturing 1.2.0
  * Design456
  * DynamicData 2.46.0
  * fasteners 0.4.16
  * FreeCAD-BlenderBIM 2022.10.20
  * freecad.archdesign
  * FreeCAD_Assembly4
  * FreeCAD_SketchArch-master
  * IconThemes
  * Manipulator 1.4.9
  * parts_library
  * sheetmetal 0.2.58
  * TabBar
  * trails
The bug is not present in LinkBranch, the current version behaves correctly as expected, without duplicating the children representation:
OS: Windows 10 (10.0)
Version: 2022.1021.26244 +5249 (Git)
Branch: LinkDaily
Hash: d307b5c936403e8dca3f24b5c1e64bd16c88b28d
Python version: 3.9.13
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
Edit: perhaps this is related to:
https://github.com/FreeCAD/FreeCAD/pull/2759
https://forum.freecadweb.org/viewtopic. ... 9&start=60
Re: [BUG] Part::FeaturePython with App::GroupExtensionPython
Post by Kunda1 »
Can you open a ticket?
captain_morgan
Post by captain_morgan »
Was a ticket ever filed for this? I cannot seem to find it if so.
I'm also encountering this issue on recent main branch and can provide a test case and open a ticket, would be great to see this resolved as I cannot see a path forward to using FeaturePython with children until it is.
captain_morgan
I've submitted a ticket for this, it's still an ongoing issue in the main branch.
https://github.com/FreeCAD/FreeCAD/issues/13237
