reduced or minimized FC window
Oli772
Post by Oli772 »
I am a running FC with its GUI in a python subprocess macro.
OS is ubuntu 20.04 on Linux. FC is 0.19.
However during the process the FC window appears to fit all the screen.
I would like to have it more discrete as a reduced window or a minimized banner.
How could this done?
Thank you for your help
onekk
Re: reduced or minimized FC window
Post by onekk »
Hello please add information required in IMPORTANT post at top of this forum.
Without proper version information it is hard to supply a solution as something may differ depending on OS and libraries versions.
It is however difficult to use "FreeCAD as a library", and to interact with the MainWindow of FC if OS is unknown as something may depend on the OS used.
Regards
Carlo D.
- Various other stuffs.
openBrain
Post by openBrain »
Something like
mw=FreeCADGui.getMainWindow()
mw.setWindowState(mw.windowState() & QtCore.Qt.WindowMinimized)
Oli772
Post by Oli772 »
thank you,
but what I get then is:
name 'QtCore' is not defined
openBrain
Post by openBrain »
Oli772 wrote: Sat Aug 20, 2022 5:43 am thank you,
from PySide2 import QtCore
Oli772
Post by Oli772 »
Thank you very much, that works: the FC starts reduced then minimized.
Do you know how it could be right minimized from the start ?
here the start of my script:
from __future__ import unicode_literals
__title__= ".."
__author__= ".."
__date__= ".."
__version__= "..."
import sys
# add folder containing FreeCAD.pyd, FreeCADGui.pyd to sys.path
sys.path.append("/usr/lib/freecad/lib")
import FreeCAD, FreeCADGui
import ImportGui
from FreeCAD import Base
import Draft, PartDesign, Part, Import
import BOPTools.SplitFeatures
#import _CommandCompoundFilter
import CompoundTools.CompoundFilter
doc = App.newDocument()
openBrain
Post by openBrain »
Oli772 wrote: Tue Aug 23, 2022 5:26 am Thank you very much, that works: the FC starts reduced then minimized.
Hmmm... I see nowhere in your code a line where you actually launch FreeCAD...
