[solved] How to reverse shape orientation (scale by -1)?
stefankorisnik3
Post by stefankorisnik3 »
I have a mesh.
How can i rotate (reshape) the mesh like in the mirror so the result mesh is in the same place as the start mesh?
I have tried following but the result mesh is not positioned where in the place of the start mesh .
@staticmethod
	def reverseModelSideMesh(mesh):
		mat = App.Matrix()
		factor = -1
		mat.scale(factor,factor,factor)
		meshCopy = mesh.copy()
		meshCopy.transform(mat)
		meshCopy.flipNormals()
		return meshCopy
Last edited by stefankorisnik3 on Fri Aug 19, 2022 11:47 pm, edited 1 time in total.
edwilliams16
Re: How to reverse shape orientation (scale by -1)?
Post by edwilliams16 »
Why are you reflecting all three axes instead of just one? The extra two are just generating a 180 degree rotation which you likely don't want.
openBrain
Post by openBrain »
What is the criteria defining the location of the original shape?
stefankorisnik3
edwilliams16 wrote: Fri Aug 19, 2022 2:31 am Why are you reflecting all three axes instead of just one? The extra two are just generating a 180 degree rotation which you likely don't want.
This is what i get with the code:
mat.scale(-1,0,0)
Screenshot (95).png (2.95 KiB) Viewed 348 times
openBrain wrote: Fri Aug 19, 2022 6:45 am What is the criteria defining the location of the original shape?
The criteria is given symmetric model
if we rotate with the algorithm "like in mirror" we get same model
edwilliams16
mat.scale(-1,0,0)
You obviously don't want that. Maybe
mat.scale(-1,1,1)
to reflect in the YZ plane
stefankorisnik3
Yes that's what i need. You guessed the right planes YZ :)
Thanks
