[solved] TechDraw exported svg has no dimensions
muzihuoyubai
Post by muzihuoyubai »
After using TechDraw to generate dimensions, the svg exported using the python script has no dimensions information.
But using GUI to export svg can have dimensions information. How to use script in console mode without running freecad GUI to export svg the same as GUI exported svg ?
TechDraw.viewPartAsSvg(App.activeDocument().View)
The output contains only shape information as below
'<g fill="none" stroke="#000000" stroke-opacity="1" stroke-width="0.7" stroke-linecap="butt" stroke-linejoin="miter" stroke-miterlimit="4">\n<path id= "1" d=" M 190.5 78.5772 L -190.5 78.5772 " />\n<path id= "2" d=" M 190.5 -70.7991 L -190.5 -70.7991 " />\n<path id= "3" d=" M 190.5 78.5772 L 190.5 -70.7991 " />\n<path id= "4" d=" M -190.5 78.5772 L -190.5 -70.7991 " />\n<path id= "5" d=" M 190.5 -78.5772 L -190.5 -78.5772 " />\n<path id= "6" d=" M 190.5 -78.5772 L 190.5 -70.7991 " />\n<path id= "7" d=" M -190.5 -78.5772 L -190.5 -70.7991 " />\n</g>\n'
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: Chinese/China (zh_CN)
test.FCStd
(16.24 KiB) Downloaded 8 times
wandererfan
Re: TechDraw exported svg has no dimensions
Post by wandererfan »
muzihuoyubai wrote: Wed Aug 17, 2022 12:46 pm After using TechDraw to generate dimensions, the svg exported using the python script has no dimensions information.
That method only exports the geometry of the view.
Dimensions are only drawn in the Gui. Only limited information about Dimensions is available on the App side.
muzihuoyubai
Thanks for your reply. From your experience, Is there any way to export a projection view with demissions without running App GUI?
wandererfan
muzihuoyubai wrote: Thu Aug 18, 2022 12:41 am Thanks for your reply. From your experience, Is there any way to export a projection view with demissions without running App GUI?
Not in the current implementation. It is possible to draw the graphics without displaying them in the Gui, but that will require a number of changes.
muzihuoyubai
Got it, thanks a lot for your help
muzihuoyubai
wandererfan wrote: Thu Aug 18, 2022 2:13 pm
