Export STEP to PrusaSlicer
demonlibra
Post by demonlibra »
PrusaSlicer 2.5.0 is able to import STEP files.
Wrote a macro to send selected models to PrusaSlicer with STEP.
# -*- coding: utf-8 -*-
# ----------- Export STEP to PrusaSlicer ------------
slicer_path = '/home/demonlibra/app/PrusaSlicer-2.5.0-beta1/prusa-slicer' # Path to PrusaSlicer
save_to_temp = True # Save step files to temp file
#save_to_temp = False # Save model near FCStd
import ImportGui
import datetime
import os
import subprocess
import tempfile
objects_to_export = FreeCADGui.Selection.getSelection()						# Выделенные объекты
slicer_args = [slicer_path]
for object in objects_to_export:														# Перебор выделенных объектов
	label = object.Label
	now = datetime.datetime.now()
	doc = FreeCAD.activeDocument()
	filename = os.path.basename(doc.FileName).partition('.')[0]
	if save_to_temp:																		# Если сохранять во временный каталог
		dirname = tempfile.gettempdir()
		file_path = os.path.join(dirname, filename)  + '-' + label + '.step'
	else:																						# Иначе сохранять рядом с файлом FCStd
		dirname = os.path.dirname(doc.FileName)
		#file_path = os.path.join(dirname, filename) + label + '_' + now.strftime("%Y%m%d_%H%M") + '.step'
		file_path = os.path.join(dirname, filename)+ '-' + label + '.step'
	slicer_args.append(file_path)
	ImportGui.export([object], file_path)											# Экспорт модели в step
subprocess.Popen(slicer_args)															# Запустить слайсер
phpBB [video]
dork
Re: Export STEP to PrusaSlicer
Post by dork »
As a PrusaSlicer user I thought at first "Great!".
But reading further at Prusa I understood that the STEP import converts the file to a triangle mesh internally before slicing.
So for now I will export the mesh from FreeCAD as usual and keep control over it.
demonlibra
Also You can use macros Export2Slicer, which export model to stl and open PrusaSlicer be one click.
