I made your bspline periodic with bspline.setPeriodic(). Its parameter range is 0 <= u < 1 Being periodic makes u + n (n integer) the same point for every n.
cuts out the segment between 3 and 4 as expected. However the trim function doesn't handle
fixes this, cutting the section out between 2 and 3 in the direction of increasing u parameter.
Note that if you want the (shorter) section between 1 and 4, starting at 1, you need
import FreeCAD
from FreeCAD import Vector
import Part
DOC = FreeCAD.ActiveDocument
if DOC is None:
FreeCAD.newDocument("test_bspline")
DEBUG = False
if DEBUG:
import sys
freecadpython = sys.executable.replace('freecad', 'python')
App.Console.PrintMessage('Using ' + freecadpython +'\n')
try:
import debugpy
except ModuleNotFoundError:
App.Console.PrintMessage('Install debugpy by: ' + freecadpython + ' -m pip install --upgrade debugpy\n')
#see https://github.com/microsoft/debugpy/issues/262
debugpy.configure(python=freecadpython)
if not debugpy.is_client_connected():
debugpy.listen(5678)
App.Console.PrintMessage("Waiting for debugger attach\n")
debugpy.wait_for_client()
debugpy.breakpoint()
poles0 = [Vector (-56.64199999999988, -108.52651511673002, 0.0), Vector (-47.7919859277423, -105.28034589991853, 0.0), Vector (-38.888377225634116, -102.18420059598452, 0.0), Vector (-29.933716868418003, -99.23896350022585, 0.0), Vector (-20.930562411786696, -96.44547580679159, 0.0), Vector (-11.881485261914264, -93.8045353684272, 0.0), Vector (-2.7890699410333184, -91.316896468599, 0.0), Vector (6.344086650735676, -88.98326960606119, 0.0), Vector (15.51537597708844, -86.80432129192957, 0.0), Vector (24.722178610566417, -84.7806738593182, 0.0), Vector (33.961864980694756, -82.91290528559352, 0.0), Vector (43.2317961250195, -81.20154902729735, 0.0), Vector (52.529324442825086, -79.64709386778577, 0.0), Vector (61.851794451321, -78.2499837776262, 0.0), Vector (71.19654354407778, -77.0106177877949, 0.0), Vector (80.56090275149953, -75.92934987570902, 0.0), Vector (89.94219750311183, -75.00648886412569, 0.0), Vector (99.33774839145133, -74.24229833293975, 0.0), Vector (108.74487193733486, -73.63699654390155, 0.0), Vector (118.16088135629343, -73.19075637827893, 0.0), Vector (127.58308732594845, -72.90370528748042, 0.0), Vector (137.00879875411403, -72.77592525665375, 0.0), Vector (146.43532354740452, -72.8074527812696, 0.0), Vector (155.85996938012778, -72.99827885669845, 0.0), Vector (165.28004446324445, -73.3483489807819, 0.0), Vector (174.69285831317472, -73.85756316939978, 0.0), Vector (184.09572252023216, -74.52577598502626, 0.0), Vector (193.4859515164646, -75.35279657826868, 0.0), Vector (202.86086334268361, -76.33838874237631, 0.0), Vector (212.21778041446356, -77.48227098070413, 0.0), Vector (221.5540302868914, -78.7841165871107, 0.0), Vector (230.86694641784777, -80.24355373927051, 0.0), Vector (240.15386892960242, -81.86016560486962, 0.0), Vector (248.9731868856047, -85.14998874821593, 0.0), Vector (258.0410087091944, -87.71242906404285, 0.0), Vector (267.315911594915, -89.37606047063355, 0.0), Vector (276.7090296974566, -90.12494317723734, 0.0), Vector (286.13036451326974, -89.95190189635201, 0.0), Vector (295.4896471853463, -88.85859459247474, 0.0), Vector (304.6972033983433, -86.85549659660789, 0.0), Vector (313.6648125772109, -83.96180023872353, 0.0), Vector (322.30655315706497, -80.20523095984058, 0.0), Vector (330.53962582549855, -75.62178166560417, 0.0), Vector (338.28514684958265, -70.25536786661178, 0.0), Vector (345.46890388643305, -64.15740690969784, 0.0), Vector (352.022067035678, -57.38632533169853, 0.0), Vector (357.88184832100256, -50.00699905589909, 0.0), Vector (362.99210328206374, -42.090131794823264, 0.0), Vector (367.30386891272974, -33.71157761508846, 0.0), Vector (370.7758327914832, -24.951614155051914, 0.0), Vector (373.37472890909754, -15.894173458784934, 0.0), Vector (375.07565640103434, -6.626037796003672, 0.0), Vector (375.8623181306826, 2.7639918269342156, 0.0), Vector (375.7271768374974, 12.185946498201766, 0.0), Vector (374.67152735393176, 21.549551421755083, 0.0), Vector (372.70548419922807, 30.765090869361334, 0.0), Vector (369.8478846689366, 39.744267776017224, 0.0), Vector (366.1261083486925, 48.401049742695974, 0.0), Vector (361.5758147815475, 56.65249334059703, 0.0), Vector (356.24060180235057, 64.41953881897251, 0.0), Vector (350.1715878127872, 71.62776760217787, 0.0), Vector (343.4269219994341, 78.2081153181218, 0.0), Vector (336.07122718758876, 84.09753352636085, 0.0), Vector (328.1749806690735, 89.23959380560476, 0.0), Vector (319.81383893649934, 93.58502841267831, 0.0), Vector (311.06791279393406, 97.09220233270787, 0.0), Vector (302.0209997893683, 99.72751219766985, 0.0), Vector (292.75978132329845, 101.4657082511312, 0.0), Vector (283.372992126182, 102.29013627433534, 0.0), Vector (273.9505700622782, 102.19289715566003, 0.0), Vector (264.5827944058706, 101.17492257456162, 0.0), Vector (255.35942084633317, 99.24596607485276, 0.0), Vector (246.36882150983, 96.42450961284332, 0.0), Vector (237.5202028867966, 93.17832912815834, 0.0), Vector (228.54791246815876, 90.28841710413747, 0.0), Vector (219.48088552023586, 87.71109112774258, 0.0), Vector (210.33000867385084, 85.44944575208109, 0.0), Vector (201.1062692370266, 83.50619649773063, 0.0), Vector (191.8207420027061, 81.88367659225872, 0.0), Vector (182.4845759514291, 80.58383416875398, 0.0), Vector (173.108980864934, 79.60822992673508, 0.0), Vector (163.70521386675577, 78.95803525824402, 0.0), Vector (154.28456590598313, 78.63403084137514, 0.0), Vector (144.85834820040026, 78.63660570292757, 0.0), Vector (135.43787865529208, 78.96575675130725, 0.0), Vector (126.03446827422198, 79.62108878023884, 0.0), Vector (116.65940757809443, 80.60181494328333, 0.0), Vector (107.32395304881051, 81.906757698592, 0.0), Vector (98.0393136137959, 83.53435022276142, 0.0), Vector (88.84751156665534, 85.61398007591114, 0.0), Vector (79.87942134582622, 88.50760264707017, 0.0), Vector (71.21543499690037, 92.21368337188969, 0.0), Vector (62.928978829625414, 96.7008136331015, 0.0), Vector (55.09027962792554, 101.93096550647208, 0.0), Vector (47.765769485807155, 107.85981404318282, 0.0), Vector (40.705096851224106, 114.10246454243367, 0.0), Vector (33.0891850669656, 119.65062891067672, 0.0), Vector (24.944104225869552, 124.38791698030678, 0.0), Vector (16.35586442629087, 128.26430412655296, 0.0), Vector (7.415155418800371, 131.23885663172535, 0.0), Vector (-1.7836110558102618, 133.28016393544735, 0.0), Vector (-11.143298231846394, 134.36667032263264, 0.0), Vector (-20.565070059637296, 134.48690254666175, 0.0), Vector (-29.949434890493947, 133.6395909841122, 0.0), Vector (-39.19729608463493, 131.8336830416769, 0.0), Vector (-48.270454181715664, 129.2804599061286, 0.0), Vector (-57.5089533295608, 127.42972731993632, 0.0), Vector (-66.89367294037379, 126.59180403182881, 0.0), Vector (-76.31391379172884, 126.7765739232957, 0.0), Vector (-85.6585576637372, 127.98185750638619, 0.0), Vector (-94.8173780548756, 130.19343763226863, 0.0), Vector (-103.6823403793832, 133.38522719227907, 0.0), Vector (-112.17085347036885, 137.4780138798098, 0.0), Vector (-120.65208512897192, 141.5914933122695, 0.0), Vector (-129.28199710883348, 145.3831450246506, 0.0), Vector (-138.0483826169826, 148.8476058211778, 0.0), Vector (-146.93884182208242, 151.97997530937928, 0.0), Vector (-155.94079939367936, 154.77582283156812, 0.0), Vector (-165.04152228969062, 157.23119373189596, 0.0), Vector (-174.2281377669716, 159.3426149501141, 0.0), Vector (-183.4876515894865, 161.10709993412962, 0.0), Vector (-192.80696640832755, 162.52215286440807, 0.0), Vector (-202.17290028758512, 163.5857721842472, 0.0), Vector (-211.57220534986374, 164.29645343092852, 0.0), Vector (-220.9915865150705, 164.65319136374202, 0.0), Vector (-230.4177203059712, 164.65548138587363, 0.0), Vector (-239.8372734695545, 164.30331626568707, 0.0), Vector (-249.22853449018976, 163.5020019746425, 0.0), Vector (-258.5580520344799, 162.1611102782264, 0.0), Vector (-267.79485060824834, 160.28509315187446, 0.0), Vector (-276.90826255916727, 157.8801792732538, 0.0), Vector (-285.8680298982814, 154.9543533420542, 0.0), Vector (-294.64440476138225, 151.51732956950514, 0.0), Vector (-303.2082481766877, 147.58051942563668, 0.0), Vector (-311.5311268109003, 143.15699375136927, 0.0), Vector (-319.58540737243305, 138.2614393612261, 0.0), Vector (-327.3443483583684, 132.91011028075388, 0.0), Vector (-334.7821888405356, 127.1207737805518, 0.0), Vector (-341.8742339959225, 120.91265138608436, 0.0), Vector (-348.59693709744846, 114.3063550591347, 0.0), Vector (-354.92797769287307, 107.32381876278644, 0.0), Vector (-360.84633571227687, 99.98822563714938, 0.0), Vector (-366.33236125806394, 92.32393102761692, 0.0), Vector (-371.3678398457723, 84.35638162121437, 0.0), Vector (-375.9360528790835, 76.11203095951754, 0.0), Vector (-380.0218331582426, 67.61825160865317, 0.0), Vector (-383.6116152375935, 58.90324427799037, 0.0), Vector (-386.6934804650339, 49.99594418926365, 0.0), Vector (-389.2571965538506, 40.925925006997495, 0.0), Vector (-391.29425155555316, 31.72330064919743, 0.0), Vector (-392.79788212090693, 22.418625304314663, 0.0), Vector (-393.7630959553371, 13.042791986440472, 0.0), Vector (-394.18668839414755, 3.6269299655461933, 0.0), Vector (-394.0672530425209, -5.797698586684166, 0.0), Vector (-393.4051864449753, -15.199802392277414, 0.0), Vector (-392.20268676877276, -24.54816495903038, 0.0), Vector (-390.46374650565167, -33.81174822427022, 0.0), Vector (-388.19413921611374, -42.95979560619893, 0.0), Vector (-385.4014003602775, -51.96193412067626, 0.0), Vector (-382.0948022789424, -60.78827522439799, 0.0), Vector (-378.28532340793083, -69.40951404965112, 0.0), Vector (-373.9856118279206, -77.7970267011743, 0.0), Vector (-369.20994327078904, -85.92296529207947, 0.0), Vector (-363.97417372189454, -93.76035040330142, 0.0), Vector (-358.295686775662, -101.28316065959544, 0.0), Vector (-352.1933359192628, -108.46641912467514, 0.0), Vector (-345.6873819360138, -115.28627622864603, 0.0), Vector (-338.7994256363284, -121.72008895240168, 0.0), Vector (-331.55233613956204, -127.74649600607765, 0.0), Vector (-323.9701749448695, -133.34548875195904, 0.0), Vector (-316.0781160431691, -138.4984776363663, 0.0), Vector (-307.90236233545636, -143.18835390995378, 0.0), Vector (-299.47005863497196, -147.39954643150082, 0.0), Vector (-290.80920154206865, -151.1180733665976, 0.0), Vector (-281.9485464910087, -154.33158860957718, 0.0), Vector (-272.9175122773122, -157.0294227745658, 0.0), Vector (-263.74608338263846, -159.2026186195549, 0.0), Vector (-254.46471042149864, -160.84396078588082, 0.0), Vector (-245.10420904033384, -161.94799975437246, 0.0), Vector (-235.69565760462729, -162.51106993862865, 0.0), Vector (-226.27029401374764, -162.53130185535292, 0.0), Vector (-216.85941198611442, -162.00862833133766, 0.0), Vector (-207.49425715903539, -160.94478472649007, 0.0), Vector (-198.1985167781159, -159.38308570070905, 0.0), Vector (-188.9523935803173, -157.54821083259674, 0.0), Vector (-179.75662582212215, -155.47567245952763, 0.0), Vector (-170.6173213759986, -153.16684717129846, 0.0), Vector (-161.5405506112146, -150.62326850059287, 0.0), Vector (-152.5323423618721, -147.84662590440263, 0.0), Vector (-143.59867992252498, -144.83876364188166, 0.0), Vector (-134.7454970740472, -141.60167954938044, 0.0), Vector (-125.97867414238848, -138.13752371347425, 0.0), Vector (-117.30403409283193, -134.44859704286455, 0.0), Vector (-108.72727723911248, -130.53748016363102, 0.0), Vector (-100.17069133143457, -126.58197619956104, 0.0), Vector (-91.56235700959934, -122.74039394627562, 0.0), Vector (-82.90379093769877, -119.01341023504551, 0.0), Vector (-74.19651862993283, -115.40168170653487, 0.0), Vector (-65.44207418183686, -111.9058446951102, 0.0), Vector (-56.641999999999854, -108.52651511673002, 0.0)]
weights0 = [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0]
knots0 = [0.0, 0.005076142131979695, 0.01015228426395939, 0.015228426395939087, 0.02030456852791878, 0.025380710659898477, 0.030456852791878174, 0.03553299492385787, 0.04060913705583756, 0.04568527918781726, 0.050761421319796954, 0.05583756345177665, 0.06091370558375635, 0.06598984771573604, 0.07106598984771574, 0.07614213197969544, 0.08121827411167512, 0.08629441624365482, 0.09137055837563451, 0.09644670050761421, 0.10152284263959391, 0.1065989847715736, 0.1116751269035533, 0.116751269035533, 0.1218274111675127, 0.12690355329949238, 0.1319796954314721, 0.13705583756345177, 0.14213197969543148, 0.14720812182741116, 0.15228426395939088, 0.15736040609137056, 0.16243654822335024, 0.16751269035532995, 0.17258883248730963, 0.17766497461928935, 0.18274111675126903, 0.18781725888324874, 0.19289340101522842, 0.19796954314720813, 0.20304568527918782, 0.20812182741116753, 0.2131979695431472, 0.2182741116751269, 0.2233502538071066, 0.22842639593908629, 0.233502538071066, 0.23857868020304568, 0.2436548223350254, 0.24873096446700507, 0.25380710659898476, 0.25888324873096447, 0.2639593908629442, 0.26903553299492383, 0.27411167512690354, 0.27918781725888325, 0.28426395939086296, 0.2893401015228426, 0.29441624365482233, 0.29949238578680204, 0.30456852791878175, 0.3096446700507614, 0.3147208121827411, 0.3197969543147208, 0.3248730964467005, 0.3299492385786802, 0.3350253807106599, 0.3401015228426396, 0.34517766497461927, 0.350253807106599, 0.3553299492385787, 0.3604060913705584, 0.36548223350253806, 0.37055837563451777, 0.3756345177664975, 0.38071065989847713, 0.38578680203045684, 0.39086294416243655, 0.39593908629441626, 0.4010152284263959, 0.40609137055837563, 0.41116751269035534, 0.41624365482233505, 0.4213197969543147, 0.4263959390862944, 0.43147208121827413, 0.4365482233502538, 0.4416243654822335, 0.4467005076142132, 0.4517766497461929, 0.45685279187817257, 0.4619289340101523, 0.467005076142132, 0.4720812182741117, 0.47715736040609136, 0.48223350253807107, 0.4873096446700508, 0.49238578680203043, 0.49746192893401014, 0.5025380710659898, 0.5076142131979695, 0.5126903553299492, 0.5177664974619289, 0.5228426395939086, 0.5279187817258884, 0.5329949238578681, 0.5380710659898477, 0.5431472081218274, 0.5482233502538071, 0.5532994923857868, 0.5583756345177665, 0.5634517766497462, 0.5685279187817259, 0.5736040609137056, 0.5786802030456852, 0.583756345177665, 0.5888324873096447, 0.5939086294416244, 0.5989847715736041, 0.6040609137055838, 0.6091370558375635, 0.6142131979695431, 0.6192893401015228, 0.6243654822335025, 0.6294416243654822, 0.6345177664974619, 0.6395939086294417, 0.6446700507614214, 0.649746192893401, 0.6548223350253807, 0.6598984771573604, 0.6649746192893401, 0.6700507614213198, 0.6751269035532995, 0.6802030456852792, 0.6852791878172588, 0.6903553299492385, 0.6954314720812182, 0.700507614213198, 0.7055837563451777, 0.7106598984771574, 0.7157360406091371, 0.7208121827411168, 0.7258883248730964, 0.7309644670050761, 0.7360406091370558, 0.7411167512690355, 0.7461928934010152, 0.751269035532995, 0.7563451776649747, 0.7614213197969543, 0.766497461928934, 0.7715736040609137, 0.7766497461928934, 0.7817258883248731, 0.7868020304568528, 0.7918781725888325, 0.7969543147208121, 0.8020304568527918, 0.8071065989847716, 0.8121827411167513, 0.817258883248731, 0.8223350253807107, 0.8274111675126904, 0.8324873096446701, 0.8375634517766497, 0.8426395939086294, 0.8477157360406091, 0.8527918781725888, 0.8578680203045685, 0.8629441624365483, 0.868020304568528, 0.8730964467005076, 0.8781725888324873, 0.883248730964467, 0.8883248730964467, 0.8934010152284264, 0.8984771573604061, 0.9035532994923858, 0.9086294416243654, 0.9137055837563451, 0.9187817258883249, 0.9238578680203046, 0.9289340101522843, 0.934010152284264, 0.9390862944162437, 0.9441624365482234, 0.949238578680203, 0.9543147208121827, 0.9593908629441624, 0.9644670050761421, 0.9695431472081218, 0.9746192893401016, 0.9796954314720813, 0.9847715736040609, 0.9898477157360406, 0.9949238578680203, 1.0]
mults0 = [4, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 4]
periodic0 = False
degree0 = 3
rational0 = False
bs0 = Part.BSplineCurve()
bs0.buildFromPolesMultsKnots(poles0, mults0, knots0, periodic0, degree0, weights0, rational0)
bs0.setPeriodic()
def build_guide_curves(base_spline, fact1, fact2):
"""Build guide curves for gordon surface."""
sp_dims = base_spline.toShape().BoundBox
xmax = sp_dims.XMax
xmin = sp_dims.XMin
ymin = sp_dims.YMin
ymax = sp_dims.YMax
dim_x = sp_dims.XLength
int_incr = 1.0
tol1 = 0.01
# Create lines to find intersection points:
lines = []
idx = 0
xpos = xmin
xpos_std_min = xmin + dim_x * fact1
xpos_std_max = xmin + dim_x * fact2
Part.show(base_spline.toShape(), "base_spline")
line1 = Part.LineSegment(
Vector(xpos_std_min, ymin - int_incr, 0),
Vector(xpos_std_min, ymax + int_incr, 0))
Part.show(line1.toShape(), "line1")
pts1 = base_spline.intersect(line1, tol1)
print(pts1, "points1")
val1 = base_spline.parameter(Vector(pts1[0].X, pts1[0].Y, pts1[0].Z))
val2 = base_spline.parameter(Vector(pts1[1].X, pts1[1].Y, pts1[1].Z))
sect1 = base_spline.trim(val1, val2)
Part.show(sect1.toShape(), "section1-2")
line2 = Part.LineSegment(
Vector(xpos_std_max, ymin - int_incr, 0),
Vector(xpos_std_max, ymax + int_incr, 0))
Part.show(line2.toShape(), "line2")
pts2 = base_spline.intersect(line2, tol1)
print(pts2, "points2")
val3 = base_spline.parameter(Vector(pts2[0].X, pts2[0].Y, pts2[0].Z))
val4 = base_spline.parameter(Vector(pts2[1].X, pts2[1].Y, pts2[1].Z))
sect2 = base_spline.trim(val3, val4)
Part.show(sect2.toShape(), "section3-4")
print(val1, val2, val3, val4)
sect3 = base_spline.trim(val2, val3 + 1)
Part.show(sect3.toShape(), "section2-3")
sect4 = base_spline.trim(val4, val1)
sect4.reverse()
Part.show(sect4.toShape(), "section1-4")
for i, val in enumerate([val1,val2,val3,val4]):
Part.show(Part.Vertex(base_spline.value(val)), 'val'+str(i + 1))
build_guide_curves(bs0, 0.2, 0.9)
DOC.recompute()
