[solved] Defining plane through two points in the space
stefankorisnik3
Post by stefankorisnik3 »
Having solid object c1Shape take two points from that object.
I want to make the plane that is normal on the z-axis and that contains both points.
I managed to find the normal vector to the plane i'm looking for but don't know what to set for the second parameter on the next function:
slices = c1Shape.slice(Base.Vector(normalizedNormal[0], normalizedNormal[1], normalizedNormal[2]),  floatOffset)
I don't know what to set for the parameter
floatOffset
I tried couple of things but didn't succeed to place my plane to go through starting points.
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * CurvedShapes 1.0.3
  * Curves 0.5.2
Last edited by stefankorisnik3 on Sun Aug 07, 2022 4:26 pm, edited 1 time in total.
onekk
Re: Defining plane through two points in the space
Post by onekk »
stefankorisnik3 wrote: Sun Aug 07, 2022 3:27 pm ...
A plane is defined by three points not collinear, it simple geometry.
https://en.wikipedia.org/wiki/Plane_(geometry)
Regards
Carlo D.
- Various other stuffs.
stefankorisnik3
I have complicated the thing.
I have three points so i do the following thing:
Make the plane with that three points and take the shape from the plane (
toShape()
than find the intersecition with the function
section
