[solved] How to do Translation instead of Rotation in this code? Coin3D
DorinDXN
Post by DorinDXN »
Due to the great help from this forum I'm able to rotate camera with this code
def RotateView(axisX,axisY,axisZ,angle):
    #Macro_Rotation_Z_axis droite
    import math
    from pivy import coin
    try:
        cam = Gui.ActiveDocument.ActiveView.getCameraNode()
        rot = coin.SbRotation()
        rot.setValue(coin.SbVec3f(axisX,axisY,axisZ),math.radians(angle))
        nrot = cam.orientation.getValue() * rot
        cam.orientation = nrot
RotateView(0,0,1,1)
How to do translation only, no rotation, on, say, the x axis?
Appreciate any help.
take care,
cheers,
Dorin
Syres
Re: How to do Translation instead of Rotation?
Post by Syres »
Based on a simple search I believe (unless it's changed) you require something like to move to X5, Y0, Z0:
camera.position.setValue(FreeCAD.Vector(5,0,0))
Have a look at https://forum.freecadweb.org/viewtopic.php?p=82414 for some inspiration.
DorinDXN
Post by DorinDXN »
Thanks,
I want camera to translate 5 on X axis instead of rotate
i.e. relative translation from the current position.
I guess I'll need to read the camera position first, then increase with 5 on x, then set camera position.
cheers,
Dorin
onekk
Post by onekk »
DorinDXN wrote: Sat Aug 06, 2022 9:57 am Thanks,
cheers,
Dorin
Sorry for the intrusion.
Could you please specify in the title that "Translation and Rotation" are relative to the camera view (managed by Coin3D) and not to the "geometric kernel" OCCT?
You could edit the title as you are the OP (Original Poster).
Simply to follow one of the advices of some developers that "forum posts are for future", this way it will be clear without opening the post that is relative to Visualization, Coin3D, "View Tab" and not Translation and Rotation properties of objects, and relative.
Regards
Carlo D.
- Various other stuffs.
DorinDXN
Re: How to do Translation instead of Rotation in this code?
Post by DorinDXN »
added "in this code"
the code provided performs rotations of the camera, I want translation instead.
onekk
Post by onekk »
DorinDXN wrote: Sat Aug 06, 2022 11:41 am added "in this code"
Thanks,
Coin3D is not know from much people (other than some coders), probably I've not explained correctly things, as I was reasoning as a "programmer" my fault, sorry.
Probably adding also information about you FC version using istruction provided here:
https://forum.freecadweb.org/viewtopic.php?f=3&t=2264
it will be better as it is versioned in case of "future changes", as forums posts hopefully will be retained for a long time, doing that if the solution proposed and proved to be useful in say 0.20.1 (as a simple example) it will be immediate to have some doubt that if it will not work in FreeCAD 2.00 as something could have changed.
For the title, IMHO maybe it is better to write something like this:
How to do camera Translation instead of Rotation?
Sorry again for bothering and thanks for your kindness.
Regards
Carlo D.
PS as example my version of FC is (among others):
OS: Artix Linux (openbox)
 Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: Italian/Italy (it_IT)
Installed mods:
  * Curves 0.5.2
you could easily see that this version is compiled using:
Python 3.9.13
Qt 5.12.9
Coin 4.0.0
OCC 7.5.3
that have some relevance when coding in Python, maybe some Python construct supported by 3.9.13 could not working of worse work different from maybe Python 3.10.0 or in Python 3.8.7.
DorinDXN
Re: How to do Translation instead of Rotation in this code? Coin3D
Post by DorinDXN »
Solved :)
def TranslateView(axisX,axisY,axisZ):
	pos = cam.position.getValue().getValue()
	cam.position.setValue(FreeCAD.Vector(pos[0]+axisX, pos[1]+axisY, pos[2]+axisZ))
TranslateView(5,0,0)
cheers,
Dorin
onekk
Post by onekk »
https://forum.freecadweb.org/viewtopic. ... 419#p82419
but how getValue() is doubled in:
Regards
Carlo D.
DorinDXN
Re: [solved] How to do Translation instead of Rotation in this code? Coin3D
Post by DorinDXN »
You can try this
print(cam.position.getValue())
print(cam.position.getValue().getValue())
cheers,
Dorin
