Toggle Drawstyle 3 style for object
demonlibra
Post by demonlibra »
Added some changes to macros Toggle Drawstyle Optimised to show object style normal, transparency and wireframe.
# triplus @ 2016, 2020
# Toggle object/global display mode
# Global drawstyle
   # 0 = "As is"
   # 1 = "Flat lines"
   # 2 = "Shaded
   # 3 = "Wireframe"
   # 4 = "Points"
   # 5 = "Hidden line"
   # 6 = "No shading"
global_drawstyle_A = 0     # As is
global_drawstyle_B = 3     # Wireframe
# Object style
   # "Flat Lines"
   # "Shaded"
   # "Wireframe"
   # "Points"
object_style_A = "Flat Lines"
object_style_B = "Wireframe"
transparency_value = 85
from PySide import QtGui
import FreeCADGui as Gui
mw = Gui.getMainWindow()
sel = Gui.Selection.getSelectionEx()
act = {
    0: mw.findChild(QtGui.QAction, "Std_DrawStyleAsIs"),
    1: mw.findChild(QtGui.QAction, "Std_DrawStyleFlatLines"),
    2: mw.findChild(QtGui.QAction, "Std_DrawStyleShaded"),
    3: mw.findChild(QtGui.QAction, "Std_DrawStyleWireframe"),
    4: mw.findChild(QtGui.QAction, "Std_DrawStylePoints"),
    5: mw.findChild(QtGui.QAction, "Std_DrawStyleHiddenLine"),
    6: mw.findChild(QtGui.QAction, "Std_DrawStyleNoShading"),
default = act[0]
actionA = act[global_drawstyle_A]
actionB = act[global_drawstyle_B]
if sel:                     # Objects selected
    obj = []
    default.trigger()
    for s in sel:
        if s.Object.TypeId == "App::Link":
            if s.Object.LinkedObject not in obj:
                obj.append(s.Object.LinkedObject)
        elif s.Object not in obj:
            obj.append(s.Object)
        else:
            pass
    for o in obj:
        if o.ViewObject.DisplayMode == object_style_A and o.ViewObject.Transparency == 0:
            o.ViewObject.Transparency = transparency_value
            o.ViewObject.LineWidth = 1
        elif o.ViewObject.DisplayMode == object_style_A and o.ViewObject.Transparency > 0:
            o.ViewObject.Transparency = 0
            o.ViewObject.DisplayMode = object_style_B
        else:
            o.ViewObject.DisplayMode = object_style_A
            o.ViewObject.LineWidth = 2
else:                       # Objects not selected
    if actionA.isChecked():
        actionB.trigger()
    else:
        actionA.trigger()
