Changing the import file doesn't get effect until restart FreeCAD
stefankorisnik3
Post by stefankorisnik3 »
I have main file and the other file that i'm including in the main file.
I have forgotten to
import Part
in the other file and get the error.
Now i fix it by adding this line in the other file but error still persist.
After restarting the FreeCAD application error is gone.
Do i need every time to restart the FreeCAD application when i need to import something in the other file?
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * CurvedShapes 1.0.3
  * Curves 0.5.2
onekk
Re: Changing the import file doesn't get effect until restart FreeCAD
Post by onekk »
stefankorisnik3 wrote: Thu Aug 04, 2022 1:38 pm I have main file and the other file that i'm including in the main file.
I have forgotten to
import Part
Installed mods:
  * Curves 0.5.2
Importing from "nested" source files, are subject to some caching mechanism, that could be on some excerpts circumvented using importlib.reload in the main file, but this use has some drawbacks.
Sadly this could not be done everytime and not as example if you program a WB, the import mechanism is derived from Python and this is a:
- known problem
- with some partial solutions
- out of control of FC developers in many aspects.
I've not found a general solution for complex and nested sources the only reliable way is to restart FreeCAD, especially when you are having erratic results.
This will avoid a lot of headaches.
Regards
Carlo D.
- Various other stuffs.
jbi
Post by jbi »
import importlib
importlib.reload(otherfile)
of course you could wrap that in a try / except block
