Creation of Surfaces
Founder
Re: Creation of Surfaces
Post by wmayer »
Help says that it "returns the initial surface" but being assigned to a variable, I don't guess what is the scope.
If no user-defined initial surface is passed to the algorithm it will create one.
onekk
Post by onekk »
wmayer wrote: Sun Aug 07, 2022 3:57 pm
Sorry I have amended the post:
https://forum.freecadweb.org/viewtopic. ... 27#p615827
including some more advancement but I obtain strange results.
Sorry for this bothering, but I wonder how to obtain this sort of solids, with some surface defined from points.
Regards
Carlo D.
- Various other stuffs.
Founder
Post by wmayer »
That's a weakness of the GeomPlate algorithm that it starts to swing when there are too many (point) constraints. I don't think it's supposed to fit well a point cloud.
onekk
Post by onekk »
wmayer wrote: Sun Aug 07, 2022 4:33 pm...
Thanks for the reply.
Do you have any hints of what is better to use to obtain a surface that fits a point cloud and could be trimmed using the base_curve to obtain a shape similar to a "musical instrument case"?
Regards
Carlo D.
Founder
Post by wmayer »
You can give this a try:
import ReverseEngineering as reen
reen.approxSurface
In the forum there once was the user microelly2 (not active any more) who has written some functionality for this kind of purpose. Check some forum postings about Gordon surface if this is of any help for you.
onekk
Post by onekk »
Many thanks, I will try some solutions and probably post here some results.
Thanks again.
Regards
Carlo D.
onekk
Post by onekk »
wmayer wrote: Sun Aug 07, 2022 5:05 pm ...
Thanks, I've done some more tests, now I need some experiments to point out things.
In meantime I've found some quirks on the "scarce" documentation obtained with:
help(reen.approxSurface)
Help on built-in function approxSurface:
approxSurface(...) method of builtins.tuple instance
approxSurface(Points=,UDegree=3,VDegree=3,NbUPoles=6,NbVPoles=6,Smooth=True,
Weight=0.1,Grad=1.0,Bend=0.0,
Iterations=5,Correction=True,PatchFactor=1.0)
That is not in line with:
https://github.com/FreeCAD/FreeCAD/blob ... eering.cpp
that a line 173 (checked now)
Is reporting different parameters.
Regards
carlo D.
