[solved] Face.Orientation bug?
onekk
Re: Face.Orientation bug?
Post by onekk »
dprojects wrote: Thu Aug 04, 2022 1:20 pm
onekk wrote: Thu Aug 04, 2022 12:49 pm
help(something)
But you can't call the command from macro? the __doc__ command works from macro so you can get all info at scanObjects just by browsing.
yes, but the problem is what data are incorporated in the sources, I 've done some analysis, some time ago:
From what I remember help() is not equivalent to __doc__, as it seems that __doc__ is more related to doctrings only, help() is aggregating some data also from sources comments.
But I have to check, as it was some months ago.
Regards
Carlo D.
- Various other stuffs.
dprojects
Post by dprojects »
onekk wrote: Thu Aug 04, 2022 2:34 pm help() is aggregating some data also from sources comments.
Yes, help print info about methods and properties. Too bad there is no way to use it in macro.
Thanks
Darek
github.com/dprojects
workbench for woodworking is available at: github.com/dprojects/Woodworking
