[Solved] Help with macro cancel
jfc4120
Post by jfc4120 »
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * Help 1.0.3
I am attempting to adapt an example from pyside examples and have a cancel work.
If I run this, it works and I can draw two lines, and no errors. However on the second loop if I hit cancel I would expect the first line to be there but of course no second line. But nothing is drawn. I am still new to this.
Code:
import FreeCAD, FreeCADGui
import Draft
from math import cos, sin, radians
from PySide import QtGui
WIRE = True
INPUTININCHES = True
if INPUTININCHES:
    convert = 25.4
else:
    convert = 1.0
getDouble = QtGui.QInputDialog.getDouble
Vector, Placement = App.Vector, App.Placement
doc = App.ActiveDocument
sel = Gui.Selection.getSelectionEx()
start_point = Vector(0, 0, 0)
if sel:
    sel, = sel
    if sel.PickedPoints:
        start_point = sel.PickedPoints[-1]
FLAG = 0
I = 1
while I < 3:
    REPLY = QtGui.QInputDialog.getText(None, "Ouija Central", "Length:")
    if REPLY[1]:
        # user clicked OK
        MYREPLY = float(REPLY[0])
    else:
        # user clicked Cancel
        #MYREPLY = REPLY[0]  # which will be "" if they clicked Cancel
        sys.exit(0)
    ANG = QtGui.QInputDialog.getText(None, "Ouija Central", "Angle:")
    if ANG[1]:
        # user clicked OK
        ANG = float(ANG[0])
    else:
        ANG = ANG[0]  # which will be "" if they clicked Cancel
    def line_length(x1=0.0, y1=0.0, z1=0.0, length=10.0, angle=0.0):
        x2 = x1 + (length * cos(radians(angle)))
        y2 = y1 + (length * sin(radians(angle)))
        z2 = z1  # + ()
        Draft.makeWire([FreeCAD.Vector(x1, y1, z1), FreeCAD.Vector(x2, y2, z2)])
    # Example:
    # x1 = 0.0          # Edit coordinate x1 origin
    # y1 = 0.0          # Edit coordinate y1 origin
    # z1 = 0.0          # Edit coordinate z1 origin
    # length = 50.0       # Edit length
    # angle  = 45.0       # Edit angle plane XY
    # line_length(x1, y1, z1, length, angle)
    length = MYREPLY * 25.4  # Edit length
    angle = ANG  # Edit angle plane XY
    I = I + 1
Also if I do hit cancel I get:
: <unknown exception data>
Edit:
Found this:
I added:
        if MYREPLY == 9999:
            return
Seems to work, didn't get any errors. But if there's a better way please let me know
Roy_043
Re: Help with macro cancel
Post by Roy_043 »
Use break instead of sys.exit(0).
heda
Post by heda »
great, it seems like you are now over the initial hurdle :-) and begin to find your way around things.
a couple of pointers (any code that works is good enough code, so this is largely style...)
- if you know the amount of iterations, use a for-loop instead of while (in this case you can set a high number, since the bailing with cancel seems to work decently)
- unpacking... using "ok" to me seems more clear for any reader than "REPLY[1]"
- using alias makes code more readable... (Vector = FreeCAD.Vector or App, which happens to be App = FreeCAD and is always available for use in a gui-session)
- function definitions generally go in zero indent (when you have it in the loop you will create it twice)
- in a "normal" python session, sys.exit kills the python session, now we are in fc python, not sure how fc deals with a sys.exit,
regardless, quitting loops is done with "break"
- python in itself does not care if you mix integers and floats, so do not have to bother about those things as long as you are in python, it could however be that when calling some fc-functions (which under the hood is c) it can be that calling it with an int does not work, so one has to convert the ints to a float in the calling (Vector for example takes both ints and floats, underlying type in a Vector is always float).
could it be that the reason for you not seeing the first edge after a cancel is that there was no .recompute?
oh, and used getDouble, since your intention is to get a float, not text... (i presume)
and the code
import Draft
WIRE = True
convert = 25.4 if INPUTININCHES else 1.0
if sel:
    sel, = sel
def line_length(x1=0, y1=0, z1=0, length=10, angle=0):
    x2 = x1 + length * cos(radians(angle))
    y2 = y1 + length * sin(radians(angle))
    z2 = z1
    Draft.makeWire([Vector(x1, y1, z1), Vector(x2, y2, z2)])
for i in range(2):
    length, ok = getDouble(None, "Ouija Central", "Length:")
    if not ok:
        break
        if i == 0:
            break
    angle, ok = getDouble(None, "Ouija Central", "Angle:")
    if not ok:
        break
    x1 = y1 = z1 = 0  # Edit coordinate origin
    length *= convert
doc.recompute()
jfc4120
Post by jfc4120 »
@heda the only thing I notice is:
    if not ok:
        break
        if i == 0:
            break
Only allows one decimal place. But:
Allows more decimal places. Why does double not allow more, like 5.75? I can only enter 5.7.
heda
Post by heda »
qt-docs:
def getDouble (parent, title, label[, value=0[, minValue=-2147483647[, maxValue=2147483647[, decimals=1[, flags=0]]]]])
so
length, ok = getDouble(None, "Ouija Central", "Length:", decimals=3)
jfc4120
Post by jfc4120 »
Thanks, where is the documentation for get double? The one I found uses float.
openBrain
Post by openBrain »
jfc4120 wrote: Wed Aug 03, 2022 6:10 pm Thanks, where is the documentation for get double? The one I found uses float.
https://doc-snapshots.qt.io/qtforpython ... .getDouble
heda
Re: [Solved] Help with macro cancel
Post by heda »
hm, or maybe you are too literal when reading things...
python only has floats, no doubles, however qt is c (and pyside is the py-wrapper around that c), so i guess the function name comes from c-double
in short, anything with a dot is a float in the python world (think one can count on that it's a f64), what the wrapper then translates that to, well, one very seldom needs to bother about that... (unless you want to code in c as well)
