Drag part elements
stefankorisnik3
Drag part elements
Post by stefankorisnik3 »
Given an simple object Part::Box how can i in the FreeCAD drag some vertex and pull it in some direction and get some deformation on the object?
I know how to register events to listen for the mouse.
I'm asking is it possible in the FreeCAD to update position of the selected element and automatically get the other adjacents elements to the selected element to follow up or do i have to recreate every time whole object manually?
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * CurvedShapes 1.0.3
  * Curves 0.5.2
edwilliams16
Re: Drag part elements
Post by edwilliams16 »
stefankorisnik3 wrote: Tue Aug 02, 2022 3:24 pm Given an simple object Part::Box how can i in the FreeCAD drag some vertex and pull it in some direction and get some deformation on the object?
You can translate objects and you can do affine (ie including shear) transformations on an object, but as far as I know if you want to change a vertex position, leaving the rest fixed, you would have to rebuild the object with the appropriate edges and faces changed. Others may know if that has be coded by someone.
This seems more like a mesh operation, where you have the luxury of assuming that edges are straight and faces are flat.
Roy_043
Post by Roy_043 »
carlopav
Post by carlopav »
Thanks @Roy_043 to mention it. It was originally coded in this PR: https://github.com/FreeCAD/FreeCAD/pull/3716
mario52
Post by mario52 »
onekk
Post by onekk »
mario52 wrote: Wed Aug 03, 2022 6:58 pm and now i play with the beautiful macro of @onekk (in progress)
Thanks, but most of the work is from @Chris_G and @mfro, I've only bothered a little and made some glue to keep things togheter.
Regards
Carlo D.
- Various other stuffs.
stefankorisnik3
Thanks to all. I didn't get to lookup all this things but planning.
Can you let me know
If i need to change single vertex in some solid object
I can find with the ancestorsOfType method the parents faces of the vertex
and further i can find the edges that are adjacent to the vertex.
Can you let me know how can i update the things in most minimal way?
How can i replace the edges in the parents faces?
Is the next thinking okay for the most minimal way:
1.Do i copy the whole array of faces from shell in the new array ?
2.Then i find and delete the parents faces in the new array with the method isSame ?
3.Insert newly created (updated the found parents) faces in the new array at the end ?
4.Construct new shell from the faces in the new array ?
