[SOLVED] How to find the faces that are adjacent to the same face?
stefankorisnik3
Post by stefankorisnik3 »
UPDATE:
OLD TITLE:How to find the faces that share same vertex or edge in shell?
Does the FreeCAD store the information aboud shared vertices or edges between faces in one shell?
If not is there some easier way to compute it beside for looping through all faces?
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * CurvedShapes 1.0.3
  * Curves 0.5.2
Last edited by stefankorisnik3 on Tue Aug 02, 2022 4:32 pm, edited 2 times in total.
edwilliams16
Re: How to find the faces that share same vertex or edge in shell?
Post by edwilliams16 »
def getSubShapeIndex(shp, sub):
    shp : a shape
    sub : a subshape (Vertex, Edge or Face)
    returns the index i of sub in shp
    e.g if sub is a Vertex in shp
    sub = shp.Vertexes[i]
    if sub.ShapeType == 'Vertex':
        for i, f in enumerate(shp.Vertexes):
            if f.isEqual(sub):
                return i
    elif sub.ShapeType == 'Edge':
        for i, f in enumerate(shp.Edges):
            if f.isEqual(sub):
                return i
    elif sub.ShapeType == 'Face':
        for i, f in enumerate(shp.Faces):
            if f.isEqual(sub):
                return i
    else:
        return -1
    return -1
obj = App.ActiveDocument.addObject("Part::Box","Box")
vindex = 0 #pick one
v = obj.Shape.Vertexes[vindex]
prstring = f'Vertex{vindex + 1}\n'
facesContainingV = obj.Shape.ancestorsOfType(v, Part.Face)
facesContainingV   #[<Face object at 0x7fa1aa86de50>, <Face object at 0x7fa19ce26a90>, <Face object at 0x7fa18c5cfe00>]
for face in facesContainingV:
    prstring += f'Face{getSubShapeIndex(obj.Shape, face) + 1}  '
print(prstring)
ancestorsOfType() is the key method. The above code finds the faces that contain Vertexes[vindex]
mfro
Post by mfro »
I think there is a simpler method to obtain same information:
theFace = p.Faces[0]
for theEdge in theFace.Edges:
    for face in p.Faces[1:]:
        for edge in face.Edges:
            if (theEdge.isPartner(edge)):
                print('edge ', theEdge, ' on face ', theFace, 'connect to ')
                print('edge', edge, 'on face', face)
The code checks for a given face of part p which edges of it are shared with others ('isPartner()' does exactly that). The same can be done for vertexes.
Cheers,
Markus
stefankorisnik3
Thanks you all.
The later answer help me because i didn't make a good question.
I was looking for how to find the faces that are adjacent to the same face.
I will change the title of my question
edwilliams16
Re: [SOLVED] How to find the faces that are adjacent to the same face?
Finding the faces shared by a vertex was basically a one-liner
However, finding the adjacent faces to a given face is a little more complicated using the ancestorsOfType() method.
def adjacentFaces(shp, face):
	shp : a shape
	face : a face in shp.Faces
	return adjacent faces ie that those share an edge
    adjFaces = []
    edges = face.Edges
    for edge in edges:
        commonFaces = shp.ancestorsOfType(edge, Part.Face) #faces that share edge
        adjFaces += [f for f in commonFaces if not face.isSame(f)] #exclude copies of 'face'
    return adjFaces
The only advantage I see is that it avoids a (potentially slow) python loop over all the faces of the object.
It isn't clear to me where isSame() or isPartner() is the more precise comparison. See https://forum.freecadweb.org/viewtopic. ... d8#p536241
When can the shared TShape have different Placements? @mfro
mfro
Post by mfro »
edwilliams16 wrote: Tue Aug 02, 2022 6:30 pm It isn't clear to me where isSame() or isPartner() is the more precise comparison. See [url]https://forum.freecadweb.org/viewtopic.php? When can the shared TShape have different Placements? @mfro
I understand e.g. an edge shared by two faces could be backwards and still visually have the same geometry (inverse parameter flow).
No idea if OpenCascade creates topologies like this, but probably the method wouldn't be there otherwise?
Cheers,
Markus
edwilliams16
mfro wrote: Tue Aug 02, 2022 6:49 pm
edwilliams16 wrote: Tue Aug 02, 2022 6:30 pm It isn't clear to me where isSame() or isPartner() is the more precise comparison. See https://forum.freecadweb.org/viewtopic. ... d8#p536241 When can the shared TShape have different Placements? @mfro
But that doesn't address my question. Both isSame() and isPartner allow edges to be oppositely oriented according to the post I quoted.
mfro
Post by mfro »
Hmmm.
Looked into the OCCT sources and found the following:
  • isPartner(), isSame() and isEqual() do exactly as documented:
    • isPartner() returns true if the TShape is exactly the same object (checks address, so there is no check for geometrical equalness as I originally assumed, inverted edges are neither considered partners, same or equal). Location and orientation aren't checked.
    • isSame() returns true if the TShape is exactly the same object *and* both the TopLoc_Locations have equal values
  • isEqual() checks for isPartner() *and* isSame() + same orientation
Bottom line is that one should probably use the most simple incarnation that's "equal enough" for your use case.
isPartner() isn't used at a lot of places inside OCCT (strangely, there are even few places where isPartner() and isSame() are both checked which seems redundant, so not even OCCT developers appear to be sure about what they need to use), isEqual() and isSame() have about the same number of occurences.
[edit: found at least one piece of code where an OCC algorithm appears to duplicate the seam edge of a closed shape (apparently to account for tolerances). In this case, neither of the tests would consider these faces adjacent. I assume these can be found only by checking for isClosed() which would make the first and last edge equal even if they aren't]
Cheers,
Markus
edwilliams16
Thanks @mfro for the research. I understand it a tiny bit more.
Being unfamiliar with OCCT and the C++ side of things I'm unclear on the role of TopLoc_Location. It seems the same piece of geometry, with a given address in memory - let us say a line segment of length 10 mm, can be shared between multiple edges with different locations? How do I create an example of an object with edges that are isPartner, but not isEqual?
Maybe this is complexity that lies in OCCT, but not exposed in FreeCAD, so the distinction is moot?
Founder
Post by wmayer »
edwilliams16 wrote: Tue Aug 02, 2022 6:30 pm When can the shared TShape have different Placements?
This usually happens for pad operations. As a test create a rectangular sketch and pad it. Hover over the bottom and top face to get their indexes. Assuming it's 5 and 6 then
pad = App.ActiveDocument.Pad.Shape
pad.Face5.isPartner(pad.Face6)
will return true.
Checking their placements:
pad.Face5.Placement # Placement [Pos=(0,0,0), Yaw-Pitch-Roll=(0,0,0)]
pad.Face6.Placement # Placement [Pos=(0,0,10), Yaw-Pitch-Roll=(0,0,0)]
From the above example you can easily see that isPartner() would lead to a false-positive check. So, you really must use isSame().
edwilliams16 wrote: Wed Aug 03, 2022 8:08 am How do I create an example of an object with edges that are isPartner, but not isEqual?
That's fairly easy. Simply create a standard box. By hovering the mouse over two adjacent faces you can see that Face2 and Face6 share a common edge.
box = App.ActiveDocument.Box.Shape
f2 = box.Face2
f6 = box.Face6
# by testing 16 possible cases you will find this shared edge
f2.Edge2.isPartner(f6.Edge3) # True
In this case isSame() will also return true because the faces are topologically connected.
f2.Edge2.isSame(f6.Edge3) # True
However, isEqual() will return false.
f2.Edge2.isEqual(f6.Edge3) # False
If you have two adjacent faces with consistent orientation then isEqual() will always return false for their shared edge.
