The idea is to code a script that for a FC version will do the following:
1) make a screenshot of the FC window
2) simulate mouse click on a menu item (and retrieve position of the menu in the window (I think that Qt has a way to determine the rectangle occupied by a QWidget))
3) make a screenshot of the menu
... select a new item and itrate through the interface to make things taking screenshots (probably noting the given name)
4) at the end (a small windows with a stop button wil be created ouside the FC mainwindow) it produce a file with:
sequence number or timestamp
action performed
screenshot name
coordinate of the activated widget
An external Python script will take this file and the screenshots and compose something like new images with superimposed "highlighting marks", like coloured ovals or similar to visualize clearly the "button or the menu item" selected, and maybe some text to be added as description
And probably using these created images (original screenshots or modified ones) compose something, that could be a "video", or a "animated gif" or similar image.
I could see some "delicate point"
It is possible to:
- determine the location of a menu item or a button in FC interface
- record the "rectangle of the activated widget" (i.e it is returned in window coordinate as pixels?)
- perform the relative action (i.e click a button or click a menu item)
Something similar was discussed as an idea some time ago, but now I don't remember the discussion, so I apologize if this post is duplicated.
TIA and Regards
Carlo D.
