My first python script cannot figure out error
jfc4120
Post by jfc4120 »
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * Help 1.0.3
Error is:
File "C:/Users/Owner/AppData/Roaming/FreeCAD/Macro/Rect_offset_get_angle.FCMacro", line 67, in <module>
FD=DE/sin(AF1)
<class 'NameError'>: name 'sin' is not defined
If you need whole script I will upload, meanwhile I tried a much smaller script:
import FreeCAD,FreeCADGui
import Draft
import math
from PySide import QtGui
A=sin(.5)
print('Angle of fitting: ', A)
Same error:
File "C:/Users/Owner/AppData/Roaming/FreeCAD/Macro/sin_test.FCMacro", line 6, in <module>
A=sin(.5)
Any help? I am using sin like here: https://wiki.freecadweb.org/Expressions
edwilliams16
Re: My first python script cannot figure out error
Post by edwilliams16 »
The sin function lives in the math module. You can either do
import math
print(math.sin(0.1))
which brings in all of the math module, but you need to prefix, or
from math import sin
print(sin(0.1))
which just imports sin into the current namespace
Expressions are not Python - it's a FreeCAD specific language. You can't put raw python into a FreeCAD file for security reasons.
jfc4120
Post by jfc4120 »
I got that part working, please see this:
In script I get:
File "C:/Users/Owner/AppData/Roaming/FreeCAD/Macro/Rect_offset_get_angle.FCMacro", line 68, in <module>
FD=DE/sin(AF1)
<class 'NameError'>: name 'AF1' is not defined
Here is script:
# -*- coding: utf-8 -*-
import Draft
from math import *
WIRE = True
INPUTININCHES = True
if INPUTININCHES:
    convert = 25.4
else:
    convert =1.0
getDouble = QtGui.QInputDialog.getDouble
Vector, Placement = App.Vector, App.Placement
doc = App.ActiveDocument
sel = Gui.Selection.getSelectionEx()
start_point = Vector(0, 0, 0)
if sel:
    sel, = sel
    if sel.PickedPoints:
        start_point = sel.PickedPoints[-1]
FLAG=0
WD, wdflag = getDouble(None, 'example', 'side view cheek width', 5)
WD *= convert
DE, deflag = getDouble(None, 'example', 'Length between ducts', 5)
DE *= convert
CL, clflag = getDouble(None, 'example', 'offset', 5)
CL *= convert
TCLRD, tclrdflag = getDouble(None, 'example', 'throat radius', 5)
TCLRD
if TCLRD == 0:
 TCLRD = .0001
CLRD = TCLRD + (.5 * WD)
FE=CL-(2*CLRD)
if FE < 0:
  FE = -1*FE
  FLAG = 1
if FLAG==1:
  TF1=FE/DE
  AF1=atan(FE/DE)
else:
  if FE == 0:
    FE = .001
    TF1=DE/FE
    AF1=atan(DE/FE)
# AF1=atan(TF1)
if FLAG==1:
  FD=FE/sin(AF1)
else:
  FD=DE/sin(AF1)      <=============== this line is 68
FC=.5*FD
JF=CLRD
CF2=CLRD/FC
AF2=acos(CF2)
if FLAG==1:
  ELDG=90-(AF1+AF2)
else:
  ELDG=180-(AF1+AF2)
print('Angle of fitting: ', ELDG)
Please remember this is my first script, but I have done basic, java, lisp, etc in past.
edwilliams16
if FLAG==1:
  TF1=FE/DE
  AF1=atan(FE/DE)
else:
  if FE == 0:
    FE = .001
    TF1=DE/FE
    AF1=atan(DE/FE)
The second if has no else clause, which could leave AF1 undefined.
EDIT: BTW
from math import *
is not recommended. You are filling up your namespace with functions likely unknown to you. Can can end up over-riding them or accidentally calling them. The bugs can be hard to find.
jfc4120
Post by jfc4120 »
Thanks for answers, for now it's solved. I didn't even know I had to convert radians to degrees. But figured it out.
onekk
Post by onekk »
Some note, usually in Python "all upper case" variables are usually used to define constants, or costant meaning variables, I use this way in my code usually for DOC to define to a FreeCAD.ActiveDocument (that is not a costant, but is referring everytime to the same object)
Using it extensively could make code less readable (me too has started with BASIC, but now some time is passed and computer have lowercase) :D
There are some rules called PEP8 for python (searching for Puthon PEP8 will help you to find them on the official python site) that are not mandatory but will ease you in learning "good habits" like using 4 spaces as indentation and other things.
In my signature you will find my "FreeCAD scripting guide" that maybe could help you to get started, it is not finished yet, but some people have found it useful.
Regards.
Carlo D.
- Various other stuffs.
