[solved] How to play an mp3 from macro?
DorinDXN
Post by DorinDXN »
Hi everyone,
I've tried winsound (with wav instead), looks like is working but but produces no sound.
then I've tried without success to install playsound module and pygame module,
again, without success :( pip simply not execute anything.
Is a simple way to play an mp3 from a macro?
thanks!
cheers,
Dorin
openBrain
Re: How to play an mp3 from macro?
Post by openBrain »
You can install PySide2 QtMultimedia package and use appropriate classes of it.
heda
Post by heda »
https://pypi.org/project/playsound/
single file - so could even copy instead of installing
at least that was the top result when searching the web...
or if that does not work there is always a system call to any audio player possible...
DorinDXN
Post by DorinDXN »
Thanks for replies, here are my findings so far
import winsound
winsound.PlaySound("S:\\Sound\\1.wav", winsound.SND_FILENAME) # OK
winsound.PlaySound("S:\\Sound\\1.wav", winsound.SND_ASYNC) # OK
#wav only, works both only in Python 3.8.10
from playsound import playsound
playsound("S:\\Sound\\1.mp3", True) # OK
playsound("S:\\Sound\\1.mp3", False) # Not Working
#works in Python  2.7.14 and Python 3.8.10, only 1st, not working in ASYNC mode, with 2nd param False
from PySide2 import QtMultimedia
QtMultimedia.QSound.play("S:\\Sound\\1.wav") # no sound
# no sound, reports :  using null output device, none available
for now I have to use winsound
unfortunately is not supported in FreeCAD 0.18 - Python 2.7.14
I'd preferred as FreeCAD 0.20 has full-screen issues on my PC (Win 7)
DorinDXN
Post by DorinDXN »
BTW, any way to have winsound working on FreeCAD 0.18 Python 2.7.14 :) ?
DorinDXN
Post by DorinDXN »
Solved for FreeCAD 0.18 Python 2.7.14 Win 7 :)
copied mp3play folder from here
https://github.com/michaelgundlach/mp3play
in the folder with macros
then made voiceplay() function and works both sync and async ,
tested with this code
import time
from threading import Thread
import mp3play
def voiceplay(filename, async):
	if async :
		thread = Thread(target=voiceplay, args=(filename, False))
		thread.start()
	else:
		voice = mp3play.load(filename)
		voice.play()
		time.sleep(voice.seconds())
voiceplay("S:\\Sound\\1.mp3", True) #async
voiceplay("S:\\Sound\\3.mp3", False)
cheers,
Dorin
