[solved] How to show an overlay image with Coin?
DorinDXN
Post by DorinDXN »
Hi everyone,
I'm currently using the below code to overlay text and works flawlessly.
It is possible to show also an image e.g. jpg, bmp ?
thank you!
cheers,
Dorin
textSep = coin.SoSeparator()
cam = coin.SoOrthographicCamera()
cam.aspectRatio = 1
cam.viewportMapping = coin.SoCamera.LEAVE_ALONE
trans = coin.SoTranslation()
trans.translation = (-0.95, -0.5, 0)
myFont = coin.SoFont()
myFont.name = "Arial"
size = 75
myFont.size.setValue(size)
SoText2 = coin.SoText2()
SoText2.string.setValues(0,3,["A","","BCD"])
SoText2.justification = 1
color = coin.SoBaseColor()
color.rgb = (0, 0, 0)
textSep.addChild(cam)
textSep.addChild(trans)
textSep.addChild(color)
textSep.addChild(myFont)
textSep.addChild(SoText2)
activeDoc = FreeCADGui.ActiveDocument
view = activeDoc.ActiveView
sg = view.getSceneGraph()
viewer = view.getViewer()
render = viewer.getSoRenderManager()
sup = render.addSuperimposition(textSep)
Founder
Re: How to show an overlay image with Coin?
Post by wmayer »
Yes, instead of an SoText2 node use an SoImage node.
cam.aspectRatio = 1
myImage = coin.SoImage()
myImage.filename.setValue("Path_to_bitmap_file")
textSep.addChild(myImage)
IIRC then by default SoImage only supports the bmp format out of the box. In order to support further image formats you need the simage plugin.
DorinDXN
Post by DorinDXN »
Works flawlessly,
Thanks a million :)
cheers,
Dorin
