is it possible to start Scripting in a polar coordinate system?
I haven't found anything regarding this and i haven't found anything regarding Freecad.vectors?
I want to move stuff in a polar coordinate system by scripting. I would also like return values of polar stuff.
I could convert it, but i have a time critical application.
cheers
blusser
[solved] Polar Coordinates Scripting
Re: Polar Coordinates Scripting
Polar coordinate are not used by FC as internally the 3d engine will use quaternions (for rotation and translation) and vectors3d.
Maybe there are ways of using polar coordinates in FC but with scripting you are working "very near" to the OCCT core so you have to supply data in a format that is used.
Probably there are methods around to specify "polar cordinate" and obtain data compatible with placement data (Translation vector and rotation).
Something similar to this:
https://github.com/FreeCAD/FreeCAD-macr ... ar.FCMacro
Regards
Carlo D.
Regards
Carlo D.
- Various other stuffs.
2D polar, 3D spherical polar, 3D cylindrical polar?
There are some methods exposed in the API you could use, but it would be less clumsy to write your own. Use numpy if you need to parallelize operations for speed, for instance the following avoids looping the interpreter over the coordinate list.
https://wiki.freecadweb.org/Vector_API
App.Base.Vector2d for 2d vectors
import numpy as np
def cart2polar(xy):
pts = np.zeros(xy.shape)
pts[:,0] = np.hypot(xy[:,1], xy[:,0])
pts[:,1] = np.arctan2(xy[:,1], xy[:,0])
return pts
arr = np.array([[1,1],[2,2],[0,1]])
cart2polar(arr) #array([[1.41421356, 0.78539816], [2.82842712, 0.78539816], [1. , 1.57079633]])
Re: [solved] Polar Coordinates Scripting
All right. Thanks for your tipps.
Even if theFreeCAD OCC glue had such methods you are looking for, it would still be required to remap polar coordinates into cartesian (since that it what OCC expects), so probably no performance increase it they were there anyway.
Cheers,
Markus
Markus
