How to set name from copyobject
grog
Post by grog »
I have a freecad script which creates a template object, then executes a copyObject -> getSelection object. This works great for multiple objects where I can create an object, specifying the name to use. It fails in the case of one object, which won't let me change the copyObject's name.
NOTE: FreeCAD versions tested: 0.19 and 0.20.
At line 298 I copy the templateobject
usb = App.getDocument(documentName).copyObject( App.getDocument(documentName).SHAPE_USB, "USBs" )
At line 339 I try to reference USBs but that fails. It turns out 'usb' is referenced by name="SHAPE_USB001", and label="USBs". The next commented line is a substitute, but it's clumsy.
    App.getDocument(documentName).addObject("Part::Cut","tray003")
    App.getDocument(documentName).tray003.Base = App.getDocument(documentName).tray002
[b]    App.getDocument(documentName).tray002.Tool = App.getDocument(documentName).USBs[/b]
    #App.getDocument(documentName).tray003.Tool = App.getDocument(documentName).getObjectsByLabel("USBs")[0]
    #In the case of only one instance of USB, the name was already created during copyObject and cannot be changed. So using label
So is there a method of setting the 'usb' object's name or assigning it's name as 'USBs' by some other function?
The script generates a tray with slots for an SD, SDmini, and USB adapters. I've tried attaching as well but there's an error. It only wants FCStd and screenshots as attachments.
Cheers,
GROG
The full python code:
#### INSTRUCTIONS #############################################################
# 1. open me as a file from within FreeCAD
# 2. set desired rows and columns
# 3. run me by clicking the play icon
#   RESOURCES:
#   http://free-cad.sourceforge.net/SrcDocu/d8/d3e/classApp_1_1Document.html
#### VARIABLES ################################################################
freecadFolder="D:/Program Files/FreeCAD 0.19/bin"
documentName='sd_scripted4'
gap='0.20'
space_x='3.00'
space_y='9.00'
floor='.50'
wall='2.40'
micro_x='0.8'
micro_y='11.0'
micro_z='13.0'
sd_x='2.1'
sd_y='24.0'
sd_z='32.0'
usb_x='4.5'
usb_y='12.0'
usb_z=micro_z
rows='2.'
micro_cols='6.'
sd_cols='6.'
usb_cols='1.'
base_x= '=2*wall + (micro_cols*(micro_x + 2*gap )+(micro_cols-1)*space_x+space_x) + (sd_cols*(sd_x+2*gap)+(sd_cols-1)*space_x+space_x) + (usb_cols*(usb_x+2*gap)+(usb_cols-1)*space_x)'
base_y= '=2*wall + rows*(micro_y + 2*gap) + (rows-1) * space_y'
base_z= '=micro_z + floor'
#### IMPORT MODULES ############################################################
import PySide
from PySide import QtGui ,QtCore
from PySide.QtGui import *
from PySide.QtCore import *
import FreeCAD
import Draft
import FreeCADGui
import math
import sys
#### FUNCTIONS ################################################################
mw=Gui.getMainWindow()
c=mw.findChild(QtGui.QPlainTextEdit, "Python console")
c.clear()
r=mw.findChild(QtGui.QTextEdit, "Report view")
r.clear()
def clear_views():
    #Clear Report View and Python Console.  Cleans up old run information
    c.clear()
    r.clear()
def setup_environment(freecadFolder,documentName):
    # add folder containing FreeCAD.pyd, FreeCADGui.pyd to sys.path
    sys.path.append(freecadFolder) # example for Windows
    doc = App.newDocument(documentName)
    #App.setActiveDocument(documentName)
    #App.ActiveDocument=App.getDocument(documentName)
    #Gui.ActiveDocument=Gui.getDocument(documentName)
    #Gui.activeDocument().activeView().viewDefaultOrientation()
    App.getDocument(documentName).recompute() # updates GUI
    return(doc)
def set_spreadsheet():
    Gui.activateWorkbench("SpreadsheetWorkbench")
    App.activeDocument().addObject('Spreadsheet::Sheet','s1')
    #Unit Dimensions
    cell = 1
    App.getDocument(documentName).s1.set(     'A'+str(cell), 'gap')
    App.getDocument(documentName).s1.set(     'B'+str(cell), gap)
    App.getDocument(documentName).s1.setAlias('B'+str(cell), 'gap')
    cell+=1
    App.getDocument(documentName).s1.set(     'A'+str(cell), 'floor')
    App.getDocument(documentName).s1.set(     'B'+str(cell), floor)
    App.getDocument(documentName).s1.setAlias('B'+str(cell), 'floor')
    cell+=1
    App.getDocument(documentName).s1.set(     'A'+str(cell), 'wall')
    App.getDocument(documentName).s1.set(     'B'+str(cell), wall)
    App.getDocument(documentName).s1.setAlias('B'+str(cell), 'wall')
    cell+=1
    App.getDocument(documentName).s1.set(     'A'+str(cell),'space_x')
    App.getDocument(documentName).s1.set(     'B'+str(cell), space_x)
    App.getDocument(documentName).s1.setAlias('B'+str(cell),'space_x')
    cell+=1
    App.getDocument(documentName).s1.set(     'A'+str(cell),'space_y')
    App.getDocument(documentName).s1.set(     'B'+str(cell), space_y)
    App.getDocument(documentName).s1.setAlias('B'+str(cell),'space_y')
    cell+=1
    App.getDocument(documentName).s1.set(     'A'+str(cell), 'rows')
    App.getDocument(documentName).s1.set(     'B'+str(cell), rows)
    App.getDocument(documentName).s1.setAlias('B'+str(cell), 'rows')
    cell+=1
    App.getDocument(documentName).s1.set(     'A'+str(cell), 'micro_cols')
    App.getDocument(documentName).s1.set(     'B'+str(cell), micro_cols)
    App.getDocument(documentName).s1.setAlias('B'+str(cell), 'micro_cols')
    cell+=1
    App.getDocument(documentName).s1.set(     'A'+str(cell), 'sd_cols')
    App.getDocument(documentName).s1.set(     'B'+str(cell), sd_cols)
    App.getDocument(documentName).s1.setAlias('B'+str(cell), 'sd_cols')
    cell+=1
    App.getDocument(documentName).s1.set(     'A'+str(cell), 'usb_cols')
    App.getDocument(documentName).s1.set(     'B'+str(cell), usb_cols)
    App.getDocument(documentName).s1.setAlias('B'+str(cell), 'usb_cols')
    #Rectangular Dimensions
    #Set column names
    cell+=1
    cell+=1
    App.getDocument(documentName).s1.set(     'B'+str(cell), 'x')
    App.getDocument(documentName).s1.set(     'C'+str(cell), 'y')
    App.getDocument(documentName).s1.set(     'D'+str(cell), 'z')
    App.getDocument(documentName).s1.set(     'E'+str(cell), 'dx')
    App.getDocument(documentName).s1.set(     'F'+str(cell), 'dy')
    App.getDocument(documentName).s1.set(     'G'+str(cell), 'dz')
    #The base
    cell+=1
    App.getDocument(documentName).s1.set(       'A'+str(cell), 'base_')
    App.getDocument(documentName).s1.set(       'B'+str(cell), base_x)
    App.getDocument(documentName).s1.setAlias('B'+str(cell),'base_x')
    App.getDocument(documentName).s1.set(       'C'+str(cell), base_y)
    App.getDocument(documentName).s1.setAlias('C'+str(cell),'base_y')
    App.getDocument(documentName).s1.set(       'D'+str(cell), base_z)
    App.getDocument(documentName).s1.setAlias('D'+str(cell),'base_z')
    #micro SD card
    cell+=1
    App.getDocument(documentName).s1.set(       'A'+str(cell), 'micro_')
    App.getDocument(documentName).s1.set(       'B'+str(cell), micro_x )
    App.getDocument(documentName).s1.setAlias('B'+str(cell),'micro_x')
    App.getDocument(documentName).s1.set(       'C'+str(cell), micro_y )
    App.getDocument(documentName).s1.setAlias('C'+str(cell),'micro_y')
    App.getDocument(documentName).s1.set(       'D'+str(cell), micro_z )
    App.getDocument(documentName).s1.setAlias('D'+str(cell),'micro_z')
    App.getDocument(documentName).s1.set(       'G'+str(cell), floor )
    App.getDocument(documentName).s1.setAlias('G'+str(cell),'micro_dz')
    #SD_
    cell+=1
    App.getDocument(documentName).s1.set(       'A'+str(cell), 'sd_')
    App.getDocument(documentName).s1.set(       'B'+str(cell), sd_x )
    App.getDocument(documentName).s1.setAlias('B'+str(cell),'sd_x')
    App.getDocument(documentName).s1.set(       'C'+str(cell), sd_y )
    App.getDocument(documentName).s1.setAlias('C'+str(cell),'sd_y')
    App.getDocument(documentName).s1.set(       'D'+str(cell), sd_z )
    App.getDocument(documentName).s1.setAlias('D'+str(cell),'sd_z')
    App.getDocument(documentName).s1.setAlias('G'+str(cell),'sd_dy')
    App.getDocument(documentName).s1.setAlias('G'+str(cell),'sd_dz')
    #USB
    cell+=1
    App.getDocument(documentName).s1.set(       'A'+str(cell), 'usb_')
    App.getDocument(documentName).s1.set(       'B'+str(cell), usb_x )
    App.getDocument(documentName).s1.setAlias('B'+str(cell),'usb_x')
    App.getDocument(documentName).s1.set(       'C'+str(cell), usb_y )
    App.getDocument(documentName).s1.setAlias('C'+str(cell),'usb_y')
    App.getDocument(documentName).s1.set(       'D'+str(cell), usb_z )
    App.getDocument(documentName).s1.setAlias('D'+str(cell),'usb_z')
    App.getDocument(documentName).s1.setAlias('G'+str(cell),'usb_dz')
    #Circular dimensions
    cell+=1
    cell+=1
    App.getDocument(documentName).s1.set(     'B'+str(cell), 'd')
    App.getDocument(documentName).s1.set(     'C'+str(cell), 'r')
    App.getDocument(documentName).s1.set(     'D'+str(cell), 'h')
def draw_base():
    print("draw_base()")
    App.getDocument(documentName).addObject("Part::Box","Base")
    App.getDocument(documentName).ActiveObject.Label = "Base" # Give it a name
    App.getDocument(documentName).getObject("Base").setExpression('Length', u's1.base_x')
    App.getDocument(documentName).getObject("Base").setExpression('Width',  u's1.base_y')
    App.getDocument(documentName).getObject("Base").setExpression('Height', u's1.base_z')
    Gui.ActiveDocument.ActiveView.viewIsometric()
    Gui.ActiveDocument.ActiveView.getViewDirection()
    Gui.SendMsgToActiveView("ViewSelection")
    Gui.SendMsgToActiveView("ViewFit")
##### Make a grid of rounds #################################################
def draw_shape_object_micro():
    #Gui.ActivateWorkbench("PartWorkbench")
    print("draw_shape_object_micro()")
    App.getDocument(documentName).addObject("Part::Box","SHAPE_MICRO")
    App.getDocument(documentName).ActiveObject.Label = "SHAPE_MICRO"  # Give it a name
    App.getDocument(documentName).getObject("SHAPE_MICRO").setExpression('Length', u's1.micro_x + s1.gap * 2')
    App.getDocument(documentName).getObject("SHAPE_MICRO").setExpression('Width',  u's1.micro_y + s1.gap * 2')
    App.getDocument(documentName).getObject("SHAPE_MICRO").setExpression('Height', u's1.micro_z')
    # Hide micro template shape
    App.getDocument(documentName).getObject("SHAPE_MICRO").ViewObject.Visibility = False
def draw_shape_object_sd():
    print("draw_shape_object_sd()")
    App.getDocument(documentName).addObject("Part::Box","SHAPE_SD")
    App.getDocument(documentName).ActiveObject.Label = "SHAPE_SD"  # Give it a name
    App.getDocument(documentName).getObject("SHAPE_SD").setExpression('Length', u's1.sd_x + s1.gap * 2')
    App.getDocument(documentName).getObject("SHAPE_SD").setExpression('Width',  u's1.sd_y + s1.gap * 2')
    App.getDocument(documentName).getObject("SHAPE_SD").setExpression('Height', u's1.sd_z')
    App.getDocument(documentName).getObject("SHAPE_SD").ViewObject.Visibility = False
def draw_shape_object_usb():
    print("draw_shape_object_usb()")
    App.getDocument(documentName).addObject("Part::Box","SHAPE_USB")
    App.getDocument(documentName).ActiveObject.Label = "SHAPE_USB"  # Give it a name
    App.getDocument(documentName).getObject("SHAPE_USB").setExpression('Length', u's1.usb_x + s1.gap * 2')
    App.getDocument(documentName).getObject("SHAPE_USB").setExpression('Width',  u's1.usb_y + s1.gap * 2')
    App.getDocument(documentName).getObject("SHAPE_USB").setExpression('Height', u's1.usb_z')
    #App.getDocument(documentName).getObject("SHAPE_USB").ViewObject.Visibility = False
def create_shape_matrix_micro():
    # https://www.freecadweb.org/wiki/Draft_PointArray
    print("create_shape_matrix_micro()")
    merge = FreeCADGui.Selection.getSelection()
    #These Commented lines get numerical values from expressions
    #micro_x = App.getDocument(documentName).s1.get("micro_x")
    #micro_y = App.getDocument(documentName).s1.get("micro_y")
    #micro_z = App.getDocument(documentName).s1.get("micro_z")
    #micro_dz= App.getDocument(documentName).s1.get("micro_dz")
    #space_x = App.getDocument(documentName).s1.get('space_x')
    #space_y = App.getDocument(documentName).s1.get('space_y')
    #wall = App.getDocument(documentName).s1.get('wall')
    #gap  = App.getDocument(documentName).s1.get('gap')
    rows = App.getDocument(documentName).s1.get('rows')
    micro_cols = App.getDocument(documentName).s1.get('micro_cols')
    for r in range ( 1 , math.floor(rows) + 1 ):
        for c in range ( 1 , math.floor(micro_cols) + 1 ):
            micro = App.getDocument(documentName).copyObject( App.getDocument(documentName).SHAPE_MICRO );
            dxStr = ('s1.wall + (%s - 1) * (s1.micro_x + 2 * s1.gap + s1.space_x)' % c)
            dyStr = ('s1.wall + (%s - 1) * (s1.micro_y + 2 * s1.gap + s1.space_y)' % r)
            #This commented line will set placement but as fixed numbers, not expressions
            #dx = wall + (c - 1) * (micro_x + 2 * gap + space_x);
            #dy = wall + (r - 1) * (micro_y + 2 * gap + space_y);
            #micro.Placement = App.Placement(App.Vector(dx,dy,micro_dz),App.Rotation(App.Vector(1,0,0),0));
            micro.setExpression('.Placement.Base.x' , dxStr )
            micro.setExpression('.Placement.Base.y' , dyStr )
            micro.setExpression('.Placement.Base.z' , u's1.micro_dz' )
            merge.append(micro)
    App.getDocument(documentName).addObject("Part::MultiFuse","MICROs")
    App.getDocument(documentName).MICROs.Shapes = merge
def create_shape_matrix_sd ():
    print("create_shape_matrix_sd()")
    sd_cols = App.getDocument(documentName).s1.get('sd_cols')
    for c in range ( 1 , math.floor(sd_cols) + 1 ):
        sd = App.getDocument(documentName).copyObject( App.getDocument(documentName).SHAPE_SD );
        dxStr = ('s1.wall + s1.micro_cols*(s1.micro_x + s1.space_x) + s1.space_x + (%s - 1) * (s1.sd_x + s1.space_x)' % c)
        dyStr = ('(s1.base_y - s1.sd_y) / 2')
        sd.setExpression('.Placement.Base.x' , dxStr )
        sd.setExpression('.Placement.Base.y' , dyStr )
        sd.setExpression('.Placement.Base.z' , u's1.sd_dz' )
        merge.append(sd)
    App.getDocument(documentName).addObject("Part::MultiFuse","SDs")
    App.getDocument(documentName).SDs.Shapes = merge
    return App.getDocument(documentName).SDs
def create_shape_matrix_usb ():
    print("create_shape_matrix_usb()")
    usb_cols = App.getDocument(documentName).s1.get('usb_cols')
    if (usb_cols == 1):
        usb = App.getDocument(documentName).copyObject( App.getDocument(documentName).SHAPE_USB, "USBs" );
        #usb.Name = "USBs" # nope, this property is read only
        usb.Label = "USBs"
        # Set Location
        dxStr = ('s1.wall + (s1.micro_cols*(s1.micro_x+s1.space_x)+s1.space_x) + (s1.sd_cols*(s1.sd_x+s1.space_x)+s1.space_x)')
        dyStr = ('(s1.base_y - s1.usb_y) / 2')
        usb.setExpression('.Placement.Base.x' , dxStr )
        usb.setExpression('.Placement.Base.y' , dyStr )
        usb.setExpression('.Placement.Base.z' , u's1.sd_dz' )
        #App.getDocument(documentName).getObject("USBs").ViewObject.Visibility = True
    else:
        for c in range ( 1 , math.floor(usb_cols) + 1 ):
            usb = App.getDocument(documentName).copyObject( App.getDocument(documentName).SHAPE_USB );
            dxStr = ('s1.wall + (s1.micro_cols*(s1.micro_x+s1.space_x)+s1.space_x) + (s1.sd_cols*(s1.sd_x+s1.space_x)) + ((%s - 1) * (s1.usb_x+4))' % c)
            print(dxStr)
            merge.append(usb)
        App.getDocument(documentName).addObject("Part::MultiFuse","USBs")
        App.getDocument(documentName).USBs.Shapes = merge
   # return App.getDocument(documentName).USBs
#def create_base():
#    print("create_base()")
#    App.getDocument(documentName).tray001.Base = App.getDocument(documentName).Base
def cut_objects():
    print("cut_objects()")
    App.getDocument(documentName).addObject("Part::Cut","tray001")
    App.getDocument(documentName).tray001.Tool = App.getDocument(documentName).MICROs
    App.getDocument(documentName).addObject("Part::Cut","tray002")
    App.getDocument(documentName).tray002.Base = App.getDocument(documentName).tray001
    App.getDocument(documentName).tray002.Tool = App.getDocument(documentName).SDs
#### MAIN #########################################################
clear_views()
doc = setup_environment(freecadFolder,documentName)
set_spreadsheet()
draw_base()
cut_objects()
#filename = documentName + '.FCStd'
#doc.saveCopy(filename)
onekk
Re: How to set name from copyobject
Post by onekk »
Hello, python code is somewhat confused:
1) some duplicate imports.
2) why you have to use a lot of:
only to refer this to the actual document?
doc = None
doc = FreeCAD.getDocument(documentName)
FreeCAD.ActiveDocument = doc
usually will suffice and you could refer to doc
Note: FreeCAD is App and FreeCADGui is Gui.
This way the code is far more readable, and probably it will be easier to find the problem.
Regards
Carlo D.
- Various other stuffs.
