Page 2 of 7
Re: Help with computing shared face.
Posted: Thu Jun 16, 2022 12:21 pm
by keithsloan52
Not sure what I am doing wrong but
for face0 in shape0.Faces :
for face1 in shape1.Faces :
if face0.isPartner(face1):
#if face0.isSame(face1):
distance, points, info = face0.distToShape(face1)
print(f'Distance {distance} points {points} info {info}')
if distance == 0.0:
Is not finding anything
Posted: Thu Jun 16, 2022 1:39 pm
by onekk
could not be that matching for 0.0 is not returning a match due to the precision.
Some caveat about matching for equality for floating point number are around, for coders, but I admit that I sometime use this writing.
usually the suggestion is:
if number <= epsilon or number >= epsilon * -1:
or similar if I have made a mess with signs, is advised with epsilon equal to the precision needed.
In some corner case it has avoided some head banging, even a simple print() statement sometimes is revealing what is going wrong.
see maybe "IEEE floating point error" if you don't know what I'm speaking about.
Regards
Carlo D.
Posted: Thu Jun 16, 2022 2:58 pm
by keithsloan52
onekk wrote: ↑Thu Jun 16, 2022 1:39 pm
Regards
Carlo D.
if distance == 0.0:
Do you mean this test for 0.0?
There is no print out before or after so it is the isPartner ( or isSame if I switch around the comments )
Posted: Thu Jun 16, 2022 3:15 pm
by onekk
keithsloan52 wrote: ↑Thu Jun 16, 2022 2:58 pm
if distance == 0.0:
EDIT:
Sorry probably my post was not clear, a part of the IEEE precision, when I spoke about print statement was also to show the match of the isPartner() and so on.
So answer to your question above is:
Yes and No.
Yes if the problem is that a 0.0 is printed but not matched by the expression as Python sometimes will make some rounding when "showing data", if I don0t go wrong there is some truncating about a precise number of decimals if no format is specified.
Sorry for not being more precise but some time ago I have banged my head prior to find this info around in python documentation, but now having not noted down were it was, my memory is not very reliable.
No if the problem is that isPartner() or isSame() is not returning True. Are you aware of this:
*Author:*
@wmayer:
https://forum.freecadweb.org/viewtopic. ... 36#p586336
I have noted some time ago an noted down as it seems interesting.
Regards
Carlo D.
Posted: Thu Jun 16, 2022 10:27 pm
by edwilliams16
I think I mislead myself on the applicability of isEqual() isSame() isPartner() methods. I think they apply to shared geometry in a single object.
I was under the impression that object names were required to be unique.
https://wiki.freecadweb.org/Object_name
Both your "GDML_Box_det" objects claim to have the same "Valid Internal Name". At the very least this makes them difficult to differentiate in python references.
I tried
Gui.Selection.clearSelection()
faces0 =[]
faces1 = []
for i in range(1,7):
Gui.Selection.addSelection('','World','Detector.GDMLBox_det.Face'+str(i))
sel = Gui.Selection.getSelectionEx('',0)
faces0.append(sel[0].SubObjects[0])
Gui.Selection.addSelection('','World','Detector001.GDMLBox_det.Face'+str(i))
faces1.append(sel[0].SubObjects[0])
for i0, face0 in enumerate(faces0):
for i1, face1 in enumerate(faces1):
print(f'i0 {i0} i1 {i1} {face0.isPartner(face1)}')
since the Gui differentiates the objects - but it only identifies the corresponding faces ignoring the lateral shift.
Posted: Fri Jun 17, 2022 6:02 pm
by keithsloan52
edwilliams16 wrote: ↑Thu Jun 16, 2022 10:27 pm
I tried
faces0 =[]
faces1 = []
I see your point, going to have to get my head around this.
Detector is a Part that contains GDMLBox_det.
Detector_001 is a Link Part and the Link is to Detector which contains GDMLBox_det, so yes the GDMLBox_det is the same object.
Now Detector_001 has a different Placement from Detector i.e. 2000,0,0 as opposed to 0,0,0 and hence the box is displayed with this Placement.
Now what I am after is what is the Common Face of the displayed boxes.
Now I thought that creating a new copy of the Shape(TopoShape) in Detector_001 and performing a translate would give me a suitable Shapes (TopoShapes) to compare,
hence
def adjustShape(part):
print("Adjust Shape")
print(part.Name)
print(part.Label)
print(part.OutList)
print(f'Before Placement Base {part.Placement.Base}')
beforeBase = part.Placement.Base
if hasattr(part,'LinkedObject'):
print(f'Linked Object {part.LinkedObject}')
part = part.getLinkedObject()
print(part.Name)
print(part.Label)
print(part.OutList)
obj = getGDMLObject(part.OutList)
obj.recompute()
# Shape is immutable so have to copy
shape = getShape(obj)
print(f'Shape Valid {shape.isValid()}')
print(dir(shape))
#return shape
print(f'After Placement Base {part.Placement.Base}')
#return translate(part, part.Placement.Base)
return shape.translate(beforeBase)
Posted: Fri Jun 17, 2022 9:44 pm
by edwilliams16
Couldn't find a definition of:
Making copies in the global coordinate system to compare, seems like a good way to start.
I tried using Part.Common to see if would return a common face - but possibly due to numerics, it didn't.
Posted: Sat Jun 18, 2022 5:42 am
by keithsloan52
edwilliams16 wrote: ↑Fri Jun 17, 2022 9:44 pm
def getGDMLObject(list):
print('getGDMLObject')
print(list[0].TypeId)
if list[0].TypeId == "App::Origin":
print(f'Vertex {list[1].Shape.Vertexes}')
return list[1]
else:
print(f'Vertex {list[0].Shape.Vertexes}')
return list[0]
Posted: Sat Jun 18, 2022 5:58 am
by edwilliams16
def shapeGlobal(part):
placement = part.Placement # in world coords
gdobjs = [obj for obj in part.OutList if 'GDML' in obj.Name]
gdobj = gdobjs[0] # only one we assume
return gdobj.Shape.copy().transformShape(placement.Matrix)
def drawFace(vs):
wire = Part.makePolygon(vs)
face = Part.Face(wire)
return face
doc = App.ActiveDocument
obj = doc.getObject("Detector")
shp1 = shapeGlobal(obj)
obj = doc.getObject("Detector001")
shp2 = shapeGlobal(obj)
v1 = [v.Point for v in shp1.Vertexes]
v2 = [v.Point for v in shp2.Vertexes]
vcommon = [v for v in v1 if any([w.isEqual(v, 1e-7) for w in v2])]
if len(vcommon) ==4:
Part.show(drawFace(vcommon))
Here's a hack, just comparing vertices.
Posted: Sat Jun 18, 2022 2:22 pm
by realthunder
In current upstream, comparing vertex is also what I would recommend you to use. Maybe also compare the bound box center of the face.
In my branch, there is a new API
TopoShape.searchSubShape() that will make the task a lot simpler. It performs not only vertex comparing under the hood, but also geometry comparing for both edge and face.
To search the sub shape, and find out the face index, use the following code
# Get transformed shape in global coordinate space
shape1 = App.ActiveDocument.World.getSubObject('Detector.GDMLBox_det.')
shape2 = App.ActiveDocument.World.getSubObject('Detector001.GDMLBox_det.')
for i, face in enumerate(shape1.Faces):
# searchSubShape() returns a list of tuple(name, subshape)
found = shape2.searchSubShape(face, needName=True)
if found:
print(f'Face{i+1} -> {found}')
In case any one requesting for a PR, please note that the code is not trivial, and will be part of the upcoming topo naming branch.
