Code snippet to demonstrate how to access, from a script, a Gui object created by the script
TheMarkster
Re: Code snippet to demonstrate how to access, from a script, a Gui object created by the script
Post by TheMarkster »
I have noticed sometimes when pasting code to the console enter must be pressed and sometimes not. This must be related to that, too.
edwilliams16
Post by edwilliams16 »
DanielLeeWenger wrote: Fri Nov 12, 2021 7:56 pm
I too have been playing with polyhedra. Below is code that I recently completed that will produce the "great rhombicuboctahedron", incorrectly called a "truncated cuboctahedron". I have been working on finding the object from which the "great rhombicuboctahedro" can be found by truncation.
Here's some code I wrote that creates a disdyakis dodecahedron
'''  Create a Disdyakis dodecahedron from vertex data'''
import Part
from math import sqrt
scaleFactor = 1.0  # =1 => middle edge length =1
#data from http://www.netlib.org/polyhedra/37  https://en.wikipedia.org/wiki/Disdyakis_dodecahedron
#these vertices are tilted and translated for no obvious reason
vertices = [
    App.Vector(2.6133122279038238, -4.3663082302150226, -7.140305645693695),
    App.Vector(2.8343891236796766, -5.0800291876449795, -7.163837801596551),
    App.Vector(2.8419869679386627, -4.0977146372750205, -6.4812216553007066),  # -X
    App.Vector(2.886667096895415, -5.0456133045766546, -6.1657984433994139),
    App.Vector(3.009894100904886, -4.0067697532409839, -7.6621114168954244),   #+ Z
    App.Vector(3.1604567932353163, -4.8973184004605509, -8.091359576603294),
    App.Vector(3.1728458528068138, -3.2955543914174693, -6.9782843659031492),
    App.Vector(3.3382971302138604, -5.6314377767564596, -7.1346547570869689),   # -Y
    App.Vector(3.3513947319758703, -3.9380673488691023, -5.9579217083010231),
    App.Vector(3.6408427234443935, -3.7812913170646378, -7.9936075282074776),
    App.Vector(3.6831062016314853, -5.5655035406455466, -6.4746655586534303),
    App.Vector(3.6907040458918208, -4.5831889902828067, -5.7920494123621763),
    App.Vector(3.8510133346080949, -5.4745586566032474, -7.655555320247756),
    App.Vector(3.8662090231277648, -3.5099295558781736, -6.2903230276597041),
    App.Vector(4.0265183118308238, -4.4012992222023037, -8.1538289355476461),
    App.Vector(4.0341161560950081, -3.4189846718394306, -7.4712127892567944),
    App.Vector(4.0763796342737318, -5.2031968954186892, -5.952270819699509),
    App.Vector(4.3658276257560316, -5.046420863604471, -7.9879566396081482),
    App.Vector(4.3789252275208671, -3.3530504357319652, -6.8112235908168941),   #+Y
    App.Vector(4.544376504923661, -5.6889338210650479, -6.9675939820056528),
    App.Vector(4.5567655644914461, -4.0871698120259693, -5.8545187713067436),
    App.Vector(4.7073282568126512, -4.9777184592536349, -6.283766931010124),    #- Z
    App.Vector(4.83055526083214, -3.9388749079095933, -7.7800799045112476),
    App.Vector(4.8752353897887335, -4.8867735752081337, -7.4646566926071458),   #+X
    App.Vector(4.8828332340508313, -3.904459024847932, -6.7820405463160945),
    App.Vector(5.1039101298205366, -4.6181799822850979, -6.8055727022155921)]
# vertices making up faces
#  No_of vertices (3), vertex_index, vertex_index, vertex_index  indices offset by 50 in data table  i.e 50 -> vertices[0]
vlist =[
    (3, 52, 56, 50),
    (3, 50, 56, 54),
    (3, 54, 55, 50),
    (3, 50, 55, 51),
    (3, 51, 53, 50),
    (3, 50, 53, 52),
    (3, 65, 72, 59),
    (3, 59, 72, 64),
    (3, 64, 55, 59),
    (3, 59, 55, 54),
    (3, 54, 56, 59),
    (3, 59, 56, 65),
    (3, 73, 69, 67),
    (3, 67, 69, 62),
    (3, 62, 55, 67),
    (3, 67, 55, 64),
    (3, 64, 72, 67),
    (3, 67, 72, 73),
    (3, 60, 53, 57),
    (3, 57, 53, 51),
    (3, 51, 55, 57),
    (3, 57, 55, 62),
    (3, 62, 69, 57),
    (3, 57, 69, 60),
    (3, 60, 69, 66),
    (3, 66, 69, 71),
    (3, 71, 70, 66),
    (3, 66, 70, 61),
    (3, 61, 53, 66),
    (3, 66, 53, 60),
    (3, 73, 72, 75),
    (3, 75, 72, 74),
    (3, 74, 70, 75),
    (3, 75, 70, 71),
    (3, 71, 69, 75),
    (3, 75, 69, 73),
    (3, 65, 56, 68),
    (3, 68, 56, 63),
    (3, 63, 70, 68),
    (3, 68, 70, 74),
    (3, 74, 72, 68),
    (3, 68, 72, 65),
    (3, 52, 53, 58),
    (3, 58, 53, 61),
    (3, 61, 70, 58),
    (3, 58, 70, 63),
    (3, 63, 56, 58),
    (3, 58, 56, 52)]
faceList = []
def makeFacesVlist(edgeList, start = 50):
    tList =edgeList[1:]
    noEdges = len(tList)
    assert noEdges == edgeList[0]
    eeList =[]
    for i in range(noEdges):
        jstart = tList[i] -start
        jend = tList[(i+1)%noEdges] - start
        #print (f'{jstart} {jend}')
        edge = Part.Edge(Part.LineSegment(vertices[jstart], vertices[jend]))
        ee = App.ActiveDocument.addObject("Part::Feature", "Edge")
        ee.Shape = edge
        eeList.append(edge)
        added = eobj.addObject(ee)
    #print(eeList)
    w = Part.Wire(eeList)
    face = Part.Face(w)
    ff = App.ActiveDocument.addObject("Part::Feature", "Face")
    ff.Shape = face
    added = fobj.addObject(ff)
    faceList.append(ff.Shape)
#find rotation and translation to orient the object on the z-axis, center at origin
xhat = (vertices[23] - vertices[2]).normalize()
yhat = (vertices[18] - vertices[7]).normalize()
zhat = (vertices[4] - vertices[21]).normalize()
rot = App.Rotation(xhat, yhat, zhat).inverted()
center = App.Vector(0., 0., 0.)
for v in vertices:
    center = center + v
center = center/len(vertices)
vertices_cen = [ v - center for v in vertices]  #center on origin
vertices_rot = [scaleFactor*rot.multVec(v) for v in vertices_cen]  #scale and rotate
print(f'Circumradius = {((vertices_rot[4] - vertices_rot[21])/2).Length}')
print(f'Edge Lengths {(vertices_rot[2]-vertices_rot[6]).Length}  {(vertices_rot[6]-vertices_rot[0]).Length}  {(vertices_rot[0]-vertices_rot[2]).Length}')
#print(f'Edge Lengths {(vertices_rot[14]-vertices_rot[5]).Length}  {(vertices_rot[5]-vertices_rot[9]).Length}  {(vertices_rot[9]-vertices_rot[14]).Length}')
shortestEdgeLength =  (vertices_rot[0]-vertices_rot[2]).Length
vertices = vertices_rot
eobj = App.ActiveDocument.addObject("App::DocumentObjectGroup","EdgeGroup")
fobj = App.ActiveDocument.addObject("App::DocumentObjectGroup","FaceGroup")
vobj = App.ActiveDocument.addObject("App::DocumentObjectGroup","VertexGroup")
pva=[]
#create vertices
for v in vertices:
    pv =App.ActiveDocument.addObject("Part::Vertex","Vertex")
    added = vobj.addObject(pv)
    pv.X = v.x
    pv.Y = v.y
    pv.Z = v.z
    pva.append(pv)
#create edges and faces
for edge in vlist:
    makeFacesVlist(edge)
#make solid
solid = Part.Solid(Part.Shell(faceList))
solidobj = App.ActiveDocument.addObject("Part::Feature", "Disdyakis dodecahedron")
solidobj.Shape= solid
#check some parameters
print(f'Volume = {solidobj.Shape.Volume}  Area = {solidobj.Shape.Area}')
print(f'Volume_theory {shortestEdgeLength**3*sqrt(3*(2194 + 1513*sqrt(2)))/7}  Area_theory {shortestEdgeLength**2*sqrt(783+ 436*sqrt(2))*6/7}')
but it can be used to create any of the polyhedra in the netlib database by editing in the vertex data
Screen Shot 2021-11-13 at 2.42.39 PM.png (20.79 KiB) Viewed 1041 times
DanielLeeWenger
Post by DanielLeeWenger »
Nice to find others working on polyhedra. Thank you edwilliams16
I am happy to find the polyhedra web site. I did not know of it.
mario52
Post by mario52 »
Hi
TheMarkster wrote: Sat Nov 13, 2021 11:05 pm I have noticed sometimes when pasting code to the console enter must be pressed and sometimes not. This must be related to that, too.
example:
copy as is and paste in the FC console Python
print("tyty")
after try this
print("tyty")
enter must be not pressed
difference ... end code without carriage return / end code with carriage return
Wmayer give the explanation (for the loop" for..."), but the topic ... in the forum
mario
TheMarkster
mario52 wrote: Sun Nov 14, 2021 11:58 am difference ... end code without carriage return / end code with carriage return
Ah, yes, that makes sense.
