already asked a similar thing on the freecad gui help forum, now I realize that is it more a Python scripting issue.
So say there is for example a cube with 6 faces. I want to have a cube of ít with 7 faces, whereas one face figures as a window in one of the remaining 6 faces. Simple, is not it?
How do I do this?
0.So I explode the original cube.
1.And then I take one face and by some manipulation I make two of it. One (2D) window and one 2(2D)-Wand,
2.and rebuild the solid out of it.
How can I acchieve 1. or. 2. in Freecad? And overmore, is that feasible in Freecad?
Tia
split face (into window,wand) and reintegrate them in solid
Re: split face (into window,wand) and reintegrate them in so
to clarify point 1.
I would like to construct such a face by script:
One other idea: Could it be, that the solution lies behind: Part.Face() or to say in the opencascade side of the code, the wrapper maybe is not well enough documented and it is unprobable that anybody of the freecaders knows about that.
Evidently the code can produce such faces, as the high level function pocket shows, does not it?
Then: should one search better in opencascade for an interface and how to use it?
tia
Update
Now I found:
viewtopic.php?f=22&t=5376#p43034
Now next Problem:
How do I position the hole-wire in the plane within the outer wire? Any ideas?
tia
Update
Now I found:
I testet it and it works fine...pass a list of several wires then the first wire is used to create the face and the further wires describe holes in this face
Now next Problem:
- windowface140411.fcstd
- (2.58 KiB) Downloaded 65 times
- windowface.PNG (3.38 KiB) Viewed 3912 times
made several tests besides described in the below code for demostrate the error. Result: bore face not working.
Think this is bug reportable.
Bye
Bye
#tests:W7 13 Part.Face from wire: triangle to outer corner, dwire:no
# drawn rectangle: triangle to outer cornerss.
#tests:W7 14 Part.Face from wire: triangle to outer corners
# makeFilledFace :No
# upgrade: No
#close and new doc
App.closeDocument(App.ActiveDocument.Name);
App.newDocument("Unnamed");Gui.activateWorkbench("DraftWorkbench")
import Draft
points=[FreeCAD.Vector(-3.40705227852,0.624237239361,0.0),FreeCAD.Vector(-3.32537651062,-0.822593152523,0.0),FreeCAD.Vector(-2.13524150848,-0.857597053051,0.0),FreeCAD.Vector(-2.22858548164,0.635905325413,0.0)]
a=Draft.makeWire(points,closed=True,face=False,support=None)
points1=[FreeCAD.Vector(-3.15035629272,0.157517880201,0.0),FreeCAD.Vector(-3.06868076324,-0.519225478172,0.0),FreeCAD.Vector(-2.5086171627,-0.53089338541,0.0),FreeCAD.Vector(-2.62529706955,0.0991778969765,0.0)]
b=Draft.makeWire(points1,closed=True,face=False,support=None)
Draft.move([b],FreeCAD.Vector(0.0,0.0,0.0),copy=False)
Draft.downgrade(FreeCADGui.Selection.getSelection(),delete=True)
b=App.ActiveDocument.Objects[len(App.ActiveDocument.Objects)-1]
Draft.move([a],FreeCAD.Vector(0.0,0.0,0.0),copy=False)
a=App.ActiveDocument.Objects[len(App.ActiveDocument.Objects)-1]
#in w7 013 no downgrade
#b=App.ActiveDocument.Objects[len(App.ActiveDocument.Objects)-2]
#a=App.ActiveDocument.Objects[len(App.ActiveDocument.Objects)-1]
App.ActiveDocument.recompute
t=Part.Face([a.Shape,b.Shape])
Part.show(t)
c=App.ActiveDocument.Objects[len(App.ActiveDocument.Objects)-1]
t=Part.Face([b.Shape,a.Shape])
Part.show(t)
d=App.ActiveDocument.Objects[len(App.ActiveDocument.Objects)-1]
Gui.getDocument("Unnamed").getObject("Wire").Visibility=False
Gui.getDocument("Unnamed").getObject("Wire001").Visibility=False
#polygon = Part.makePolygon(points)
#polygon1 = Part.makePolygon(points1)
#polygonf = Part.Face(polygon)
#polygonf1 = Part.Face(polygon1)
#t=Part.Face([polygon,polygon1])
#Part.show(t)
#Part.show(polygonf)
- holeface_isolated_points140412Windows_0.13.PNG (25.66 KiB) Viewed 3894 times
http://www.freecadweb.org/tracker/view.php?id=1510
workaround:Shape.cut
#close and new doc
import Draft
DWire=App.ActiveDocument.Objects[len(App.ActiveDocument.Objects)-1]
DWire001=App.ActiveDocument.Objects[len(App.ActiveDocument.Objects)-1]
diff=DWire.Shape.cut(DWire001.Shape)
Part.show(diff)
#bore
http://www.freecadweb.org/tracker/view. ... 1510#c4568
Here is the solution. Thanks for that wandererfan
In the script pcb.py there is a
applied to the inner wire. I had read something like that in occ's forum.
One needs to study the occ interface. At this point at least I do not know where to get this peace of infomation. Maybe someone could put such a hint in the wiki.
w2 = r2.Shape.OuterWire
w2.reverse() # make w2 an inside contour
