How to intersect a line with a part
microelly2
Postby microelly2 » Thu Jan 23, 2014 3:04 pm
Given two points P1,P2 I want to find the intersection of the line P1P2 with a Part-Object.
I use the following code
import Part,PartGui
App.newDocument()
App.setActiveDocument("Unnamed")
App.ActiveDocument=App.getDocument("Unnamed")
# the test part
App.ActiveDocument.addObject("Part::Box","Box")
myBody=App.activeDocument().Box
App.ActiveDocument.addObject("Part::Line","Line")
# Point 1
App.ActiveDocument.Line.X1=0.00
App.ActiveDocument.Line.Y1=0.00
App.ActiveDocument.Line.Z1=0.00
# Point 2
App.ActiveDocument.Line.X2=100.00
App.ActiveDocument.Line.Y2=30.00
App.ActiveDocument.Line.Z2=400.00
# App.ActiveDocument.Line.Placement=Base.Placement(Base.Vector(0.00,0.00,0.00),Base.Rotation(0.00,0.00,0.00,1.00))
myLine=App.activeDocument().Line
# is there a shorter way th an the next lines?
App.activeDocument().addObject("Part::MultiCommon","Common")
App.activeDocument().Common.Shapes = [myLine,myBody]
y=App.activeDocument().Common
z=y.Shape.Edges[0].Vertexes[1]
# RESULT OUTPUT
z.X
z.Y
z.Z
I hope that there is function to calculate the coordiantes without the helper common object.
thank you for some tipps.
ulrich1a
Re: How to intersect a line with a part
Postby ulrich1a » Fri Jan 24, 2014 7:04 pm
microelly2 wrote:I hope that there is function to calculate the coordiantes without the helper common object.
The common object seems to me a good solution. You just need not so much code, when the common object should not be visible in your document, as you can see here: http://www.freecadweb.org/wiki/index.ph ... tersection
y = myline.common(myBody)
Regards
Ulrich
wandererfan
Postby wandererfan » Sat Jan 25, 2014 6:46 pm
This should get you started. It works with a line and a solid, but won't work for 2 lines or a line and a face.
#!/usr/bin/env python
# -*- coding: utf-8 -*-
# example for intersection of shape(Solid) & line(Edge)
# Usage: select a line and a solid, then run this macro
# http://www.forum.freecadweb.org/viewtopic.php?f=22&t=5456
import FreeCAD
import Part
s = FreeCADGui.Selection.getSelection()
if len(s) < 2:
    print "not enough objects selected - ", len(s)
s1 = s[0].Shape
s2 = s[1].Shape
cs = s1.common(s2)
if cs.Vertexes:
    for v in cs.Vertexes:
        print "intersection point : ", v.Point
else:
    print "can't find an intersection point"
wf
mario52
Postby mario52 » Fri Dec 20, 2019 9:09 pm
hi wandererfan
I create a macro with your snippet Macro_FCSpring_On_Surface for Zwei Helix - ein Sweep
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
cron
