how to use Web Kit widgets ?
k0nichiWa
Post by k0nichiWa »
I haven't worked with QtWebKit, I guess in PySide2 its QWebEngine or something like that
I found some information but it appears to be outdated
https://wiki.freecadweb.org/Code_snippe ... om_webpage
>>> from PySide import QtGui,QtWebKit
ImportError: cannot import name 'QtWebKit'
Is there some import I can use to pop-up a QDialog and display some HTML ? Thought this would be an easy way to provide a "Help" button for a Task Panel macro I'm working on
OS: macOS 10.13
Version: 0.18.16146 (Git)
Branch: (HEAD detached at 0.18.4)
Python version: 3.6.7
Qt version: 5.6.2
TheMarkster
Re: how to use Web Kit widgets ?
Post by TheMarkster »
This seems to work, but there might be a different preferred way.
from PySide2.QtWebEngineWidgets import QWebEngineView
mario52
Post by mario52 »
hi
this run (convert to PySide2)
merci bernd Browser inside task panel
##https://forum.freecadweb.org/viewtopic.php?f=22&t=47224&sid=0a58cca8ad2a3b2aeff6c1aedd889517
##https://forum.freecadweb.org/viewtopic.php?f=10&t=25189
##08/06/2020
import FreeCAD
import FreeCADGui
from PySide2 import QtCore, QtGui, QtWidgets
from PySide2 import QtWebEngine
from PySide2.QtWidgets import *
from PySide2.QtCore import *
from PySide2.QtGui import *
class TransWindow(QtWidgets.QDialog):
    HOME = "https://wiki.freecadweb.org/Macro_Compound_Plus"
    def __init__(self):
        super(TransWindow, self).__init__()
        self.webView = QWebEngineView()
        self.webView.setSizePolicy(QtWidgets.QSizePolicy.Expanding, QtWidgets.QSizePolicy.Expanding)
        self.layout = QtWidgets.QVBoxLayout(self)
        self.layout.addLayout(QtWidgets.QHBoxLayout())
        self.layout.addWidget(self.webView)
    def showEvent(self, event):
        super(TransWindow, self).showEvent(event)
        self.webView.load(QtCore.QUrl(self.HOME))
mw = FreeCADGui.getMainWindow()
d = QtWidgets.QDockWidget()
d.setWidget(TransWindow())
#mw.addDockWidget(QtCore.Qt.LeftDockWidgetArea, d)
mw.addDockWidget(QtCore.Qt.RightDockWidgetArea, d)
#### other copy content web page ######
###https://forum.freecadweb.org/viewtopic.php?f=22&t=47224&sid=0a58cca8ad2a3b2aeff6c1aedd889517
#import PySide2
#from PySide2 import (QtWidgets, QtCore, QtGui)
#import requests
##contentPage = requests.get("https://wiki.freecadweb.org/Macro_Compound_Plus").text
##memo        = PySide2.QtGui.QClipboard()    # Clipboard
##memo.setText(contentPage)                   # copy contentPage on Clipboard
##for i in content.split("\n"):               # list page to line
##    print(i)
#### other ##########################
#import WebGui
#WebGui.openBrowser("https://wiki.freecadweb.org/Macro_Compound_Plus#Choice")
mario
k0nichiWa
Post by k0nichiWa »
QTextBrowser turns out was good enough for me ... it can display most HTML tags, not complicated CSS
it think it was PySide.QtGui.QTextBrowser
called setHtml(" ... html string ... ")
bernd
Post by bernd »
code without comments and not needed imports less new lines:
import FreeCADGui
from PySide2 import QtGui
from PySide2 import QtWidgets
    def __init__(self):
runs on :
OS: Windows 10 (10.0)
Version: 0.19.22130 (Git)
Hash: dc65b055e5143a7d7349520da466d4d722df57e8
Python version: 3.6.8
Qt version: 5.12.1
Locale: German/Switzerland (de_CH)
mario52
Post by mario52 »
hi
thanks
mario
