k0nichiWa
Posts: 10 Joined: Fri May 01, 2020 5:48 pm
Post
by k0nichiWa » Wed Jun 03, 2020 10:10 pm
I haven't worked with QtWebKit, I guess in PySide2 its QWebEngine or something like that
I found some information but it appears to be outdated
https://wiki.freecadweb.org/Code_snippe ... om_webpage
>>> from PySide import QtGui,QtWebKit
ImportError: cannot import name 'QtWebKit'
Is there some import I can use to pop-up a QDialog and display some HTML ? Thought this would be an easy way to provide a "Help" button for a Task Panel macro I'm working on
OS: macOS 10.13
Version: 0.18.16146 (Git)
Branch: (HEAD detached at 0.18.4)
Python version: 3.6.7
Qt version: 5.6.2
TheMarkster
Posts: 5513 Joined: Thu Apr 05, 2018 1:53 am
Post
by TheMarkster » Sat Jun 06, 2020 12:29 am
This seems to work, but there might be a different preferred way.
from PySide2.QtWebEngineWidgets import QWebEngineView
mario52
Posts: 4692 Joined: Wed May 16, 2012 2:13 pm
Post
by mario52 » Mon Jun 08, 2020 2:19 pm
hi
this run (convert to PySide2)
merci bernd
Browser inside task panel
##https://forum.freecadweb.org/viewtopic.php?f=22&t=47224&sid=0a58cca8ad2a3b2aeff6c1aedd889517
##https://forum.freecadweb.org/viewtopic.php?f=10&t=25189
##08/06/2020
import FreeCAD
import FreeCADGui
from PySide2 import QtCore, QtGui, QtWidgets
from PySide2 import QtWebEngine
from PySide2.QtWidgets import *
from PySide2.QtCore import *
from PySide2.QtGui import *
class TransWindow(QtWidgets.QDialog):
HOME = "https://wiki.freecadweb.org/Macro_Compound_Plus"
def __init__(self):
super(TransWindow, self).__init__()
self.webView = QWebEngineView()
self.webView.setSizePolicy(QtWidgets.QSizePolicy.Expanding, QtWidgets.QSizePolicy.Expanding)
self.layout = QtWidgets.QVBoxLayout(self)
self.layout.addLayout(QtWidgets.QHBoxLayout())
self.layout.addWidget(self.webView)
def showEvent(self, event):
super(TransWindow, self).showEvent(event)
self.webView.load(QtCore.QUrl(self.HOME))
mw = FreeCADGui.getMainWindow()
d = QtWidgets.QDockWidget()
d.setWidget(TransWindow())
#mw.addDockWidget(QtCore.Qt.LeftDockWidgetArea, d)
mw.addDockWidget(QtCore.Qt.RightDockWidgetArea, d)
#### other copy content web page ######
###https://forum.freecadweb.org/viewtopic.php?f=22&t=47224&sid=0a58cca8ad2a3b2aeff6c1aedd889517
#import PySide2
#from PySide2 import (QtWidgets, QtCore, QtGui)
#import requests
##contentPage = requests.get("https://wiki.freecadweb.org/Macro_Compound_Plus").text
##memo = PySide2.QtGui.QClipboard() # Clipboard
##memo.setText(contentPage) # copy contentPage on Clipboard
##for i in content.split("\n"): # list page to line
## print(i)
#### other ##########################
#import WebGui
#WebGui.openBrowser("https://wiki.freecadweb.org/Macro_Compound_Plus#Choice")
mario
k0nichiWa
Post
by k0nichiWa » Mon Jun 08, 2020 2:44 pm
QTextBrowser turns out was good enough for me ... it can display most HTML tags, not complicated CSS
it think it was PySide.QtGui.QTextBrowser
called setHtml(" ... html string ... ")
Posts: 12851 Joined: Sun Sep 08, 2013 8:07 pm
Post
by bernd » Fri Aug 07, 2020 7:18 am
code without comments and not needed imports less new lines:
import FreeCADGui
from PySide2 import QtGui
from PySide2 import QtWidgets
def __init__(self):
runs on :
OS: Windows 10 (10.0)
Version: 0.19.22130 (Git)
Hash: dc65b055e5143a7d7349520da466d4d722df57e8
Python version: 3.6.8
Qt version: 5.12.1
Locale: German/Switzerland (de_CH)
mario52
Post
by mario52 » Sat Aug 08, 2020 8:58 am
hi
thanks
mario
