[Help]Update Related Objects
HakanSeven12
Post by HakanSeven12 »
I have a point cloud object and I created mesh from them but I want to update mesh when I do changes on point cloud. Is there a way for it?
HakanSeven12
Re: [Help]Update Related Objects
Any idea?
onekk
Post by onekk »
I suspect there is not a method to do so.
When you create a mesh you will transform a bunch of vertex in a mesh, the only way i could think , is to reload the points, but this involve to delete the old mesh and regenerate a new mesh, it is a sort of conversion, once converted the object is not related anymore to the original one.
In fact the workflow is to create a Mesh populated it with points
Did you read this?
https://wiki.freecadweb.org/Mesh_Scripting
There is a way to do so, a little involute way, from the page linked, there is a method to export the mesh to a file and to reload it into a new mesh, maybe using this technique, you could export the imported mesh, and reload it on demand.
However, this warning is put on the page describing the Mesh Module:
However, in the field of engineering meshes present one big limitation: they are only made of surfaces, and have no mass information, so they don't behave as solids. This means that all solid-based operations, such as addition or subtraction, are difficult to perform on meshes.
Regards
Carlo D.
- Various other stuffs.
HakanSeven12
I see. Thanks for answer.
